Question about GE JBP24 QuickClean Electric Kitchen Range
We were given a GE model #JBP26GV3AD The clock works, the upper electric burners are fine. The oven does not turn on, although my wife said the upper heating element worked, albeit slowly. I have completely replaced the control panel with a new one, we replaced the lower heating element, which was obviously burned, even broken at one place. Using an electrical tester, I have been able to determine that the current at the outlet is 220, the connector end of the wire into the stove is 220, splitting into 110, the top controls for each electric burner are showing power of 220, but no power showing through any leads connecting into either the broiler or oven. Sadly, when I removed the lower heating element, I could have sworn there are only 2 wires I removed, but I pulled those 2 wired through to test their leads, and when plugging the stove in, experienced a large spark, where I saw yet a 3rd black wire had touched the metal - and I have no idea where that wire is supposed to connect to. It would make sense to me that it is the power wire to the lower heating element, which I see also has a yellow wire connecting to the bake control, then a purple wire connecting the upper heating element. I probably should hire a service tech at this point, but thought I'd ask for your help first.
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
SOURCE: replacing baking element for GE Truetemp
I just had the same problem. Just remove the rear panel of the range and unplug the two leads. Now go to the two screws inside the oven and remove them. The heating element will now come out and you can insert the new element the same way. Replace the two screws inside the oven and then attatch the two leads in the rear. Replace the rear panel and you are set to go.
Posted on Feb 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
  • 198 Answers
SOURCE: Our GE electric stove was working fine and then
check circuit breaker
Posted on Feb 20, 2009
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Oven not heating and oven control lights not working
Check if the oven is in AUTO cook mode. It should be in MANUAL cook mode , check if it has a MANUAL mode button. Sometimes resetting the clock will put it back into MANUAL mode.
Nov 05, 2008 | GE JBP25 Electric Kitchen Range
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Oven
Neal, the only thing I can bring up with that model number is a built in wall oven. You said the top burners work fine, so we are missing something here. Sounds to me like a stuck or shorted keypad. Catriver..post back
Sep 14, 2006 | GE JKP15 Electric Single Oven
GE JBP24 QuickClean Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
