Question about Ryobi Factory Reconditioned 10-Inch 18 Volt One+ Cordless Electric Chain Sa
I just bought a Ryobi 18v cordless chain saw. Filled the oil reservoir, pumped etc and used. Left it overnight and now the contents of the reservoir are all over my garage floor. Instructions said to except some leakage but is this normal? It seems to have completely emptied.
    Problem Solver:
  • 5 Answers
Man, I know what you mean. If I am not going to use my saw, I empty my saw oil back into
the oil bottle using a large funnel to catch it all. Then I can put the saw in a large cardboard box
lined w/layers of newspaper in an upright position til next time. Works great! Get back to me if
you need help sharpening that puppie...............dansky66
Posted on Mar 27, 2011
Do you have a better pruner?
Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw ...
? 13:42
www.youtube.com/watch?v=PFANQ0JgpZk
Jun 12, 2013 - Uploaded by 8digitPDX The Ryobi 18v Power pruning saw - surprisingly good performance for the money from a ... Ryobi P4360/P4361 Cordless 18v ONE+ System Pole Saw Tree Pruning Saw .... Lithium-ionPole Saw - Unboxing and Review!
Oct 08, 2015 | Garden
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Excessive use of chain oil
Unlike most bigger gasoline powered chainsaws, the Ryobi RCS2040 electric chainsaw does not have an oil adjuster. The oil pump on it is pretty much a simple mechanism that moves the oil on a "cork screw" -it rotates when your chainsaw runs, then your oil glides out of the reservoir into the tube towards the chain oiler. Amount of oil used will depend on two factors: 1.) Type of oil used. We sell winter grade and summer grade (but we are in Southern California, this doesn't make any difference). Our customers prefer the less tackier ones because it doesn't burn their bars under heavy use and it is less strain on the unit, however this drips out fast. 2.) Integrity of your oil line system, and the size of your reservoir (on your model, it IS small). Our rule of thumb here is that if it drips bar & chain oil, it's working. Well, that is unless it's leaking someplace else other than the bar oiler. Check the oil tube - it should be on the bottom of your chainsaw right on the same side as the oil tank.
Generally, speaking for both mid-sized electric and gas powered saws - 45 minutes of worth of cutting should have your bar and oil tank depleted already. Our contractor customers even have it opened way up.
Jan 12, 2014 | Ryobi Garden
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What type of oil do you put in the reservoir?
is it 2 stroke? if so 2 stoke oil mixed with petrol regards
Feb 03, 2010 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Sep 28, 2009 | Ryobi P501 18v Circular Saw Only
Ryobi 18 Volt Cordless Chainsaw needs chain oil?...
you can use a reg bar oil or a lightweight motor oil
Aug 11, 2009 | Garden
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Jul 15, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi cordless chain saw leaks oil. Runs fine. When I remove battery and store on shelf...a few days later I notice a puddle of oil. What to do?
The problem is, that it doesn't require 'movement or inertia', to draw/or pump the oil.
It syphons through, naturally.
The only solution is, to not store it with oil remaining in the reservoir.
That's it I'm afraid.
There is no way, to stop it from drawing oil through, without stopping it from working correctly.
Happy, (& safe;) chopping.
& plz don't give me the thumbs up, thanks :)
Jul 12, 2009 | Garden
Oil flow problem
had the same problem on my husqy 136. replaced oil pump, no joy. filled oil tank with brake cleaner fluid and left overnight then ran saw, this cleared blockage in oil feed pipe and everything is now ok.
Jan 07, 2009 | Husqvarna 450 e-series 18" Chain Saw
Ryobi Factory Reconditioned  10-Inch 18 Volt One+ Cordless Electric Chain Sa Logo
331 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
