Question about Honda Garden
Doesn't retain its high power pressure for more than about 10 minutes and then it goes to being like a regular hose. Usually never regains that power unless I leave it off for a long time and sometimes even then it doesn't recover.
    Genius:
  • 1,114 Answers
The pressure washer may need new gaskets. When these fail, then you get the same result. The gaskets are available online, and at a Honda dealer.
Posted on Mar 26, 2011
Need help with installing the high pressure power hose on my Acura 2002 RL
I assume you are talking about the high pressure power steering hose? It's not that hard to do. Start at the pump and remove the end of the hose. It's bolted to the pump. Follow the hose down the frame and remove the bolts holding the retaining clips. Save them! You'll need them for the new hose. Way at the other end of the hose is your rack and pinion. It's a little tough to unscrew the pressure fitting. Use a tubing wrench or crowfoot wrench on your ratchet. Install the new hose starting at the pump and reattach all the retaining clips, making sure you orient the new hose just as the old one was. Last screw in the pressure fitting to the rack and pinion. There may be an o-ring you need to put on this end before you install it. Look for one in the package your new hose came in. When done and all fittings tight, refill power steering fluid reservoir and start engine, Turn steering wheel all the way left and right several times, this will bleed air from the system. Check for leaks, if none, you're done. Check you tube for videos before you begin, they can be very helpful!
Feb 02, 2018 | Acura Cars & Trucks
HOW DO I REPLACE THE HIGH PRESSURE LINE FOR A POWER STEERING UNIT ON A 1998 MUSTANG?
Disconnect battery ground cable.
Remove engine Air Cleaner (ACL) .
Disconnect electrical connector in back of engine cooling fan motor.
Remove radiator fan shroud.
Disconnect constant control relay module harness from headlamp harness and place constant control relay module on top of engine to provide accessibility to power steering lines.
Remove wiring harness guide retaining screws and position guide aside.
Remove screw at power steering hose bracket.
Remove anti-rattle clip.
Remove plastic strap retaining tubes to power rack and pinion steering gear.
Remove power steering pressure hose at power steering pump.
Remove power steering pressure hose at power rack and pinion steering gear.
Remove power steering pressure hose from vehicle.
Reverse procedure to install new hose.
Fill and bleed power steering system.
Aug 20, 2011 | Ford Mustang Cars & Trucks
On a 99 Olds Alero, in the return lines of the power steering hoses, which place does the high pressure hose attach to?
RETURN TURN LINE GOES TO THE LEFT OF RACK PINION AND HIGH PRESSURE HOSE GOES TO THE RIGHT OF RACK PINION.LOOKING AT POWER STEERING PUMP HIGH PRESSURE HOSE THICK HOSE SCREWS INTO POWER STEERING PUMP.WHILE LOW PRESSURE HOSE HAS A HOSE WITH A CLAMP THE LOW PRESSURE HOSE HOOKS TO TOP OF POWER STEERING PUMP.LOW PRESSURE DONT SCREW INTO POWER STEERING PUMP IT IS HELD IN PLACE BY A HOSE SMALL CLAMP.
Jun 24, 2011 | 1999 Oldsmobile Alero
I have a 1992 Crysler Imperial. The ABS light is on and the ABS pump runs all the time. Help.
Either the ABS Module is bad or the Pump is bad--- Pump REMOVAL & INSTALLATION 1989-90 Models
  1. Disconnect the negative battery cable. Depressurize the hydraulic accumulator. CAUTION
    Failure to depressurize the hydraulic accumulator, prior to performing this operation may result in personal injury and/or damage to the painted surfaces.
  2. Remove the fresh air intake ducts.
  3. Disconnect all electrical connectors to the pump motor.
  4. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap the spigot on the reservoir.
  5. Disconnect the shift selection cable bracket from the transaxle and move it aside.
  6. Loosen the nuts on the 2 studs that position the pump/motor to the transaxle differential cover.
  7. Remove the retainer bolts that are used to mount hose bracket and pump/motor. The engine inlet water extension pipe is also held in position by these bolts. NOTE: Do not disturb the inlet water extension pipe, or engine coolant will leak out.
  8. Disconnect the wiring harness retaining clip from the hose bracket.
  9. Lift the pump/motor assembly off of the studs and out of the vehicle.
  10. Remove the heat shield from the pump/motor, if equipped and discard. To install:
  11. Place a new heat shield onto the pump/motor bracket, using fasteners provided.
  12. Install the pump/motor assembly onto the studs.
  13. Install the wiring harness retaining clip onto the hose bracket.
  14. Install the retainer bolts to the hose bracket and pump/motor. Tighten securely.
  15. Tighten the 2 nuts until secure.
  16. Install the shift selection cable bracket onto the transaxle.
  17. Connect the high and low pressure hoses to the hydraulic assembly and tighten to 13 ft. lbs. (17 Nm).
  18. Attach all electrical connectors to the pump/motor.
  19. Install the air ducts.
  20. Readjust the gearshift linkage, if it was disturbed.
  21. Connect the negative battery cable and check the assembly for proper operation.
1991-95 Models
  1. Disconnect the negative battery cable. CAUTION
  2. Depressurize the brake system.
  3. Remove the fresh air intake ducts from the engine.
  4. Remove the clip holding the high pressure line to the battery tray.
  5. Disconnect the electrical connectors running across the engine compartment in the vicinity of the pump/motor high and low pressure hoses. One of these connectors is the one for the pump/motor assembly.
  6. Disconnect the high and low pressure hoses from the hydraulic assembly. Cap or plug the reservoir fitting.
  7. Disconnect the pump/motor electrical connector from the engine mount.
  8. Remove the heat shield bolt from the front of the pump bracket. Remove the heat shield.
  9. Lift the pump/motor assembly from the bracket and out of the vehicle. Fig. 1: The pump/motor assembly mounts to the top of the transaxle case and is covered by a heat shield 86729g75.gif
    To install:
  10. Fit the pump motor assembly onto the bracket; install the heat shield and its retaining bolt.
  11. Install the pump/motor electrical connector to the engine mount.
  12. Connect the high and low pressure hose to the hydraulic assembly. Tighten the high pressure line to 145 inch lbs. (16 Nm). Tighten the hose clamp on the low pressure hose to 10 inch lbs. (1 Nm).
  13. Connect the electrical connectors which were removed for access.
  14. Install the high pressure line retaining clip to the battery tray if it was removed.
  15. Install the fresh air intake ducts.
  16. Bleed the brake system.
Oct 07, 2010 | 1991 Chrysler Imperial
How to recharge recharge airconditioner
Hi, determine if your car uses R134 or R12 refrigerant. You will notice screw type connectors on the both the High Pressure Side and Low Pressure Side lines in models using R12 refrigerant. R134 compatible models have quick connect valves on both sides. Models made before 1995 may use the old R12 refrigerant. If this is the case, you must have your Chrysler's air conditioning system retrofitted to use R134 refrigerant. Mixing R12 and R134 refrigerants is dangerous and may cause damage to your vehicle. Check your air conditioning system pressure using an automotive air conditioning pressure gauge. Keep in mind that in order to get an accurate reading, the air conditioner has be turned on the coldest setting with maximum blowing power. Remove the Low Pressure Side port valve cap and set it aside. The location of the port varies, but it is usually in front of the engine block. Attach the refill hose to the port on the Low Pressure Side of the air conditioning system. The Low Pressure Side port is smaller the High Pressure Side port. Because the ports are different sizes, the refill kit hose should fit only on the Low Pressure Side port. Additionally, the High Pressure Side port will usually have a red cap or be marked with an H or the word High Allow the air conditioner to **** the refrigerant out of the can by slowly turning the valve on the refill kit hose. Pay attention to the way you hold the can. Most kits will have you hold the can upright when you recharge the air conditioning system. It may take as long as 10 minutes to empty a single can. Turn the valve to the off position and remove the refill hose from the port. Recap the port before closing the hood. Let the air conditioner stay on for at least 30 minutes. This allows the refrigerant to move throughout the entire system.
Take care
Aug 03, 2010 | 2006 Chrysler Town & Country
On a 1994 olds cutlass supreme SL can i put a regular rubber hose over a leak on the power steerings high pressure hose to buy myself time before i can afford to replace it? i plan on hose clamping it...
If it is a small leak you might be able to wrap it with a rubber hose and apply several clamps to put a band-aid on it. However, this is only temporary at best and could still cause problems depending on where it is leaking. One possible alternative to a new hose - if you take the hose to a shop like The Hoseman (or equivalent) they can rebuild the hose cheaper than buying a new one.
Jan 30, 2010 | 1994 Oldsmobile Cutlass Supreme
The nossle that connects the hose to the unit keeps flying off. Where can I buy a NON PLASTIC part that will hold?
It is easy to NOT get the connector attached properly. The O ring and the end MUST go into the connector a reasonable distance so that the retaining ring will have MANY threads engaged.
The hoses are NOT servicable in general and usually have to be replaced as the pressure is so high that liability of supplying DIY connectors precludes offering them.
Oct 13, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Subaru impreza 1993 power steering leak
YOU CANT USE A REGULAR FUEL LINE ON POWER STEERING AS A HIGH PRESSURE HOSE.BECAUSE POWER STEERING PRESSURE IS 1000 PSI.YOU HAVE TO BUY THE POWER STEERING HIGH PRESSURE HOSE IT HAS NUMBER OF PLIES MATERIAL WEAVES TO MAKE IT STRONG.IT WAS MADE FOR POWER STEERING HIGH PRESSURE.YOU DONT HAVE A BLOCKAGE .THE HIGH PRESSURE HOSE JUST WORE OUT.REPLACE IT .IT SHOULD FIX THE PROBLEM.
Sep 04, 2009 | 1993 Subaru Impreza
A/C compressor works intermittently
Hello< will try and help you.Try replacing the low pressure switch,and the high side compressor cut out switch,look on the low side for the low pressure switch(large line/hose).It will have to wires gong to it.The high side cut out switch will be on the high side line/hose,or in the back of compressor.If this doesn`t help Have the system pressures checked.If I can help anymore...roniecon@gmail.com
Jul 17, 2009 | 2000 Volkswagen Beetle
Nissian NXR Coupe with an SR20 Motor
If it goes from the power steering reservoir down directly to the rack, it's a low pressure hose. If it goes from the pump to the rack, it's the high pressure hose. The high pressure hose is usually 2-3 times the price of the low pressure one. Not sure what the pricing will be, but they can tell you at the auto parts store (probably significantly cheaper than buying directly from Nissan).
Aug 31, 2008 | 1992 Nissan NX
Garden Logo
55 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
