Have a baxi lunia 310fi.heat works fine .no hot water.it started as hot then none then hot.hard to shower.then would only heat h2o if i first started heat.now when i start heat,turnh2o on heat shuts off instantly ,fire out no hot h2o. need help plus manual.
SOURCE: moen posi-temp for shower pressure
There is a little "o" ring in the shower inlet that is designed to collapse as the pressure increases, limiting flow. You can safely remove this and then have un restricted flow.
Posted on Feb 24, 2009
  • 659 Answers
SOURCE: Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Posted on Mar 21, 2009
  • 16 Answers
SOURCE: Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Posted on Aug 17, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
SOURCE: got a Alpha HE CB33
Problem is normally the hot water flow switch -
Posted on Jan 11, 2010
Hot water at showers is intermitent while shower is on
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Set timer so pump is off when shower time arrives
Check for crossover
Check if installation is correct... is the crossover valve installed correctly?
Gene
Feb 02, 2012 | Grundfos Comfort System Recirculator ...
I have been strugling with water flow after replacing a single handle tub and shower cartridge. I have no flo. They have pex plumbing. the shower has not been used for a while and at the time they were...
look inside the valve with a flashlight and make sure a rubber peice of the cartridge did not plug the cold side this cartridge needs hot and cold water to function it has a built in balancer that prevents scalding also make sure its not shut down at a manabloc system in the mechanical room if this helped you please feedback vote thanks
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
No constant hot water from baxi 105e
Im guessing this is a boiler with on demand hot water or a on demand heater, if so a common problem is most on demands can only supply 3-4gpm so if you have a low flow shower head running it will keep up if you exceed the gpm output rating which can be found either in tech. specs. or on name plate. Keep in mind a tub faucet usually supplys 6gpm. Im talking in canadian gallons if I remember correct it is about 1 litre smaller than a US gallon.
Solutions; holding tank circuit, flow restrictor PRV on hotwater line. None of which are great options, buyer be ware of this common problem when buying on demand. Buy a hi efficient condensing hot water tank instead in my opion then you have capacity and can also use for hydronic heating.
Dec 01, 2008 | Computers & Internet
Nov 02, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
