Question about Car Audio & Video
2010 Buick Enclave. Where can I find switched accessory power for Rosen headrest dvd's? The fuse block under the glove box is always hot, I need it to go off when the key is off. The yellow wire to the 120v outlet in the back of the console does not have enough amps to run both dvd's.
4 Suggested Answers
gopakumarg43
  • 75591 Answers
SOURCE: Mounted rosen box on top
Hello
Have you checked your car video player Rosen R5505 properly. If it doesn't power up, connections may have some trouble.
This unit is exclusively for cars with a negative ground, 12V
power supply.
If your unit doesn't come up, check the 3AMP fuses connected in series with the main +ve power rail. There are three wires from the rear power socket, colured yello, red and black. Out of which Black wire is --Ve or ground.
Yello is meant for constant power +12VDC, and red is meant for +12v accessory supply.
Whe fitted in the car, the yellow wire is connected to the ON-OFF switch, to power the unit when needed and the red wire is connected before the ON-OFF switch, so that there will be power ot the control section of the unit to retain memory and all other previous setting levels. In otherwords, red wire must be connected ot the battery terminals, and yellow wire must be connected after the switch of the car. This is the wiring status when the unit is in the car. Black wire is meant for ground or cars chasis.
When the unit is powered ouside the car, the red and yello wires must be shorted and connect to the +ve and the black to --ve. Then obly the unit will live up. OK.
Posted on Dec 10, 2010
  • 13 Answers
SOURCE: need to install headrest dvd
if you dont want to run it to the power outlet run it to the ignition fuse this way when the car is off so is the dvd player
Posted on Dec 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Both DVD Headrest players on
Are these factory installed, or aftermarket displays?
Posted on Aug 06, 2011
Buick enclave front wipers work only on high speed.
What year ? The relay's are located in the under hood fuse box .
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER relay, the WIPER HI relay and the WSH relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics. Which wipers are you talking about ? Front or rear . Rear wiper fuse is in the I/P instrument panel fuse box .
Fuse Block - I/P
Under the lower right side of the instrument panel
Nov 19, 2016 | Buick Enclave Cars & Trucks
Whereisthecabinairfilteron 2010buickenclave
under the glove box there is an access panel remove panel and replace filter
Oct 15, 2014 | 2010 Buick Enclave
Why do my dome lights not come on when door is open?
The dome light is on a separate fuse since the dome light is one of the few lights that are connected to the battery even if the key is off.
There are usually two relay/fuse boxes
One under the hood on the drivers side near the firewall.
The other place is under the dash to the left of the drivers knee.
Hope this helps.
Sep 06, 2014 | 2010 Buick Enclave
Where is under hood lever to release hood in a 2014 Buick Enclave
On this website (link below) you find fuse box diagram and description for Buick Enclave 2014
http://www.autogenius.info/en/buick-enclave-2014-fuse-box-diagram
Feb 13, 2014 | Cars & Trucks
Locating the fuse box on a 2010 buick enclave
You find here (website Autogenius.info - link below) - information about fuse box, location and description for Buick Enclave - 2010
http://www.autogenius.info/en/buick-enclave-2010-fuse-box-diagram
Feb 18, 2013 | 2009 Buick Enclave
Where id the fuse box for the radio located in a 2008 buick enclave.
The instrument panel fuse block is located under the instrument panel on the passenger side of the vehicle. Pull down on the cover to access the fuse block....Hope tis helped you ?
Jun 29, 2011 | Buick Enclave Cars & Trucks
Need to install headrest dvd to fuse box, but do not know which wire is hot on accessory or run do not want to connect to power outlet , this is always hot.
Dec 15, 2010 | 2007 Ford Explorer Eddie Bauer
Location of batter 2010 Enclave
You will probably find the battery under the hood on the left or right in this vehicle and the fuses box under the left hand side dash by the driver. But it may be on the right hand side under the dash too. Easy to find either way. Hope this helps and you have a kind heart to give me a good thumbs up, Raz
Apr 19, 2010 | 2009 Buick Enclave
How to locate the fuse box in a '94 buick regal glove box?
The main fuse block is located in the underside of the instrument panel, in or behind the glove compartment. Remove the access cover in the glove compartment to access the fuse block. Spare fuses and a fuse puller should always be kept here. Various convenience connectors, which snap-lock into the fuse block, add to the serviceability of this unit.
On some vehicles, you may have to remove a cover for access to the main fuse block
The main fuse block is in or under the glove compartment
Dec 22, 2009 | 1994 Buick Regal Gran Sport
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
