Question about Cameras
I have a Canon Rebel XT, and by mistake I pressed FORMAT CF Card and lost all the pictures on my card. Is there any way to get them back or are they gone for good??
  • miriamw Aug 04, 2008
    Thanks!
    Genius:
  • 1,689 Answers
Yes you can, all you have use is a recovery tool to get your files back on the memory card or other media storage.
an example of the tool is the one below.
File Rescue Plus
you may use the free trail version of it.
for more option you may refer to the results below.
Accidental Format Data Rescue
Posted on Aug 04, 2008
I have a Cannon EOS Digital Rebel Xti. When I try taking a picture, I keep getting an error message indicating there is a problem with the CF Card. I have replaced the card several time but keep getting...
What you require is to format the Compact Flash Card. The CF card should be formatted when new and after every download. Format the card in the camera it is going to be used it. Constantly deleting pictures on the memory card will cause major corruptions and total failure. Formatting cleans the memory and allows the camera to communicate properly with the CF Card.
I going to give you several diagrams on where to go in your camera to format. these diagrams are screen shots right from your manual.
Dec 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
While using my Canon Rebel XT camera today the 4MB CF card only allowed me to take a few pictures and then the "CF Full" started to blink. I deleted the card but it is continuing to blink "Full CF".
mine has done this to me before.
dump all of your photos on to your computer
put the card back in the camera
in playback mode, hit the menu button.
in the menu, scroll over to the first settings tab.
there should be a "format" option.
Format your card.
this *should* fix it.
Sep 26, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Formatting a SanDisk for my Canon Rebel Xt failed
Formatting the card completely erases it. Your pics are gone.
Feb 22, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
8 GB CF card has made the camera lose the Raw function even when I return old 1GB CF card still the same... any ideas?
1st, make sure the camera is in the Creative zone P, TV, AV, M or A-Dep. I have made this mistake many time and everytime I forget I moved the dial.
If dial is in the Creative Zone and still no RAW option then have the camera format the card, if that doesn't work do the following:
Turn off camera,
Remove lens,
Put on body cap.
Remove CF Card
Remove Battery
Let sit for about 30 minutes.
Put battery back in.
Put CF Card back in
Turn camera on
Put camera in Creative Zone
Push Menu button
Push Set button twice and check if RAW is now an option
If not then you can try the clear all settings function in the Set-Up 2 menu. Push the menu button then the left arrow button arrow down to the clear settings line push set the clear all functions.
If this doesn't help then I would say carry it to your nearest Canon Dealer that offers cleaning and service.
May 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT won't read my CF card
The card needs to be formated by the camera itself. It should be an option in the menu somewhere. Wish I could be more specific but I dont have a rebel. Remember though formatting erases pictures pictures so if you have anything on the card you will want to get that stuff saved before formatting.
Apr 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lost previous pics after checking used memory on CF card
have you used the card since if not there is a program you can download that can help recover the datahttp://www.pcinspector.de/Sites/smart_recovery/info.htm?language=1
Feb 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF Card not being detected
Jerseygirl98 does your computer reckonize the card if not it may be a bad card. That does happen..I the computer does right click on the card and rename it .JERSEYGIRLCAMERA
THEN LOOK FOR IT..Try to format the card in the computer..No luck just get another card..
Dec 24, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
