Question about Vivitek V37655 56" DLP TV
I have a Vivitek RP51HD41-A TV. Yesterday it made a pop sound then sizzling and the picture went out. I unplugged it, the plugged back in. No picture. Looked to see if lamp burned out but small green light is on inside. The front lights blink on and off orange. No message calme up to replace the lamp like in the past. Any suggestions?
  • ryser Mar 27, 2011
    So you are saying I have to take it to a technician to have it tested. I have had a hard time in the past finding someone to look at this TV, it doesn't seem to be a known brand. Any other suggestions would be appreciated.
    Thanks, Sandy
  • 2,098 Answers
Hi ryser,
Pop sound is coming from the parts either on the ballast board(lamp's driver) or power supply(ballast board supply). It means that you're bulb is not the issue that's why you've not encountered the led lamp indicator. Check the ballast board for faulty electrolytic capacitor, blown fuse/fusible resistor, shorted ballast transformer. Also check the power supply parts like bulged electrolytic capacitor, shorted voltage regulator transistor. If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for an experienced technician to troubleshoot the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 27, 2011
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    You may check the ballast board first, look for bulged capacitor and open fuse/fusible resistor if you found one, replaced with same ratings. Let me know what you've discover...
I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
May 29, 2012 | Vivitek V37655 56" DLP TV
I need to install a colorwheel for a vivitek model rp51hd41-a...is there a manual on-how-to available?
Hello
I've with me procedure to replace a colour wheel to DLP tv. But I can't upload it to you by this site as it doesn't allow me to upload more that 50KB of document, and the procedure with me is much above this capaity. It has pictures about how to proceed and eloborate. If you wants it, send your email ID to me by Fixya. OK.
Mar 04, 2011 | Televison & Video
What remote controls that are compatiable to Vivitek model RP51HD41-A and what are the codes to use to the compatiable remote control?
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Sep 25, 2010 | Televison & Video
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
Jan 14, 2010 | Vivitek V37655 56" DLP TV
Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
Oct 22, 2009 | Vivitek Televison & Video
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
Technical support
My Hitachi TV has a red shadow ,its like seeing two of everything in red. M Kretsch
Apr 16, 2008 | Televison & Video
Vivitek V37655 56" DLP TV Logo
346 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
