Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
When i turn on the chlorinator its comes on and then turns the power off to the whole unit
    Problem Solver:
  • 5 Answers
Please dragon, Be careful. If the chlorinator is not wired to the unit correctly you could ven have a
flash!! 1. Shut off the circuit breaker located on the house. Ir's located in
metal rectangular panel. Probably next to the elect meter.
2 Now that the power is off check the wiring where the chlor attaches to the pump.
The wires should be color coded. Black & red are always the hot leads, white & green are
neutral leads, Let me know........dansky66
Posted on Mar 26, 2011
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
Pool turned green pump not working only 1 month old
could you be more specific?
Is it the pump or the chlorine generator?
or the whole unit
There is a lot more to keeping a pool clear other than the filter and generator
Once I know about the pump I can go into more detail on the chemical side of things
Jun 16, 2010 | Intex Automatic Salt Water System for ...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
Zodiac LM3 24S won't turn ON
Two Things come to mind, the board, or it could be that the life of the cell has expired.
The Pool Tech
Jul 13, 2009 | Zodiac Duo Clear System Chlorine...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
120 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
