I need a pin configeration on mobo E206922 PS 1
  • cgced Mar 27, 2011
    Sorry there is no M7XXX number on the board that is the only number on the board
    President:
  • 1,623 Answers
There is a code on the motherboard that starts M7xxx i need to know that to give you a link to a manual
Posted on Mar 26, 2011
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
D102GGC2 will not do anything!
Hi there. Have you tried running the system as a barebone?
What I mean by this:
Disconnect everything from the mobo, all memory sticks, cables, wires, and any PCI/AGP cards you may have.
If you have more than 1 memeory stick, only put 1 back in. Connect the power switch to the mobo.
Now connect the power supply to the board.
Connect the monitor to the On Board VGA port.
Now turn it on. Let me know what, (if anything), happens.
Tim
Apr 25, 2009 | Intel D102GGC2 Motherboard
K8N motherboard
Have you tried a secondary PSU? (though it sounds like your motherboard needs replacing)
May 23, 2008 | ASUS K8N Motherboard
Asus P5N-E SLI Mobo will not boot or post.
Hi bart, please re-check you're memory. See page 1-17 in you're user manual. (Read everything)!
You're Asus board can not use 184-pin DDR DIMM's.
Also check the QVL list for supported memory page's 1-18 & 1-19.
I did not see Corsair on either page.
You're board can only use 240-pin DDR2 memory. Please read the "Notes" at the top of page 1-18.
If everything (Regarding memory) is within the Asus specifications than clear the cmos/bios & re-boot again. If you're system still does not boot than remove one DIMM & try again.
Asus warrants their boards for three years. Call Asus tech at
1-812-282-2787 EST, IL 8:00AM to 5:00PM. The call is on you but the service is free. It's worth every dime.
Good Luck & Kind Regards.
Would you be kind enough to let me know what Asus suggested? (If it comes to that).
Mike
May 15, 2008 | ASUS P5NSLI (0610839134670) Motherboard
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Suddenly quit and won't start.
Could be a processor failure, but try changing the cmos battery first on the mobo and locate 'JBAT1' terminal on mobo and put jumper across pins 2-3 then back to pins 1-2 and try starting up again.
Jan 09, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
171 people viewed this question
Alun Cox
David Payne
David Payne
