Question about Kenmore Dryers
Dryer stops before clothes are dry...have to wait a few minutes before it will start again but only stays running for a short time.
  • Kenmore Master
  • 2,699 Answers
If the dryer is running and then the motor stops when it gets hot it sounds like you have a bad motor.when was the last time you cleaned out the dryer and vent line?also i need the model number,on some kenmore dryers they have even heat that can cause this to happen if it's in your machine the timer will count down faster than normal and shut down ,or you could have a bad thermister so send the model number and i can check it out for you.
Posted on Mar 26, 2011
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Gas dryer does not completely dry
Replace the glowbar ignitor and also the gas valve coils.
Aug 18, 2009 | Kenmore Dryers
My dryer stops running before the clothes are dry. You have to wait a few minutes and then start it again once it has cooled down
clean and check the lint filter and the exhaust duct, run the dryer and go outside to the vent and check for proper air flow. if it is blowing good may be a thermostat internally causing the issue
Aug 15, 2009 | Kenmore Dryers
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Dryers Logo
117 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
