I can't connect to Toshiba HDD/DVD/Video cassette recorder. The screen says no video / audio signal.
  • 1 more comment
  • hiromisak Mar 26, 2011
    SL738B Regza Toshiba
    HDMI
  • hiromisak Mar 27, 2011
    I have two HDM inputs and have tried both but no success.
  • 2,098 Answers
Hi hiromisak,
May I know the model no. of your TV, same as well as the toshiba to assist you further.
Jdvillanueva
Posted on Mar 26, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva Mar 26, 2011
    are you using a RCA or HDMI cable?
  • Jdvillanueva
    Please check if you've selected the right input (HDMI1/HDMI2/HDMI3/HDMI4) where the player was currently hooked up, your unit(TV) has 4xHDMI input.
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    I have a copy of your user's manual (page 11-15) and stated here the latest version of HDMI format(currently your TV format) will not support some older format. You may used other input connectors like through RCA cables.
Toshiba dvd recorder will not record from webcam it is hooked into the ubs line
Do you mean USB? According to the manual for your DVD recorder, the USB port is only for the playback of MP3 (audio) or JPEG (photo) files. So you can't record video from your camera through the USB port.
http://support.toshiba.com/support/staticContentDetail?contentId=2912443&isFromTOCLink=false
Jun 06, 2016 | Toshiba DR430 DVD Player/Recorder - 1080p...
Connect sony dvd to samsung tv
There are five ways to get the video and audio signals from the DVD player: HDMI, Coaxial, Audio/Video, S-video and Component video, which way did you use?
Jun 07, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I have a Toshiba RDXV59DTKB2 Hdd & DVD/Video
The control board is shot including the on/off switch.
Jan 21, 2013 | Televison & Video
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I own a D-VR7KC2 DVD VIDEO RECORDER / VIDEO-CASSETTE RECORDER TOSHIBA, the problem is I can record only some of my DVD's to the VCR, on certain discs a red circle with a red line through it shows up on the...
You must have a show that has an anti-copy signal imbedded into the show causing it to not be recorded. This is due to DRM rules on copy right materials.
Sep 10, 2017 | Toshiba D-VR4 DVD Recorder/VCR
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
No sound through channels on hdd dvd
If you are taking output from the Red, Green Blue connectors (Component) from your video source and plugging them into your hd dvd recorder, you need a sound channel as well. The S-video carries both audio & video but not in high-definition. Sounds like you've got the 3 channels for your video (RGB-component) connection now you need an audio signal into your HD DVD recorder. That will be 1 fibre connection or 2 cables. Let me know if you get it working & good luck!
Nov 13, 2008 | Wharfedale DVD-M3 DVD Player
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
