Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Colors will not algin and picture has ghosts
  • Hitachi Master
  • 2,098 Answers
Hi sbsoto,
If the symptom didn't cure by convergence adjustment through the remote control, this is an indication of faulty convergence board inside. You may replace the convergence IC's and some of the resistor around because its already gone bad. You may also replace the entire convergence board for your convenient. If the board replaced with new one, your unit will back to normal again. Also, consider bad solder jointsin that area, it will do the same symptom like what you've encountered right now. Find it first and re-solder. If you don't have necessary tools and test instrument and can't do the job yourself, I would advise you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 26, 2011
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My projection tv has ghost pic you can see three dfferent color lines
Go into the tv menu and look for "convergence" this is a setup issue that can sync your colors. Projection tv's have 3 projectors inside, each a different color, if they get out og sync it can cause a blue or red ghost. In your tv menu you can look for noise reduction and turn it on also scan velocity modulation turn that on as well. These can all be found in the menu under picture or setup.
Jul 01, 2009 | Televison & Video
Ghosting
fuser could be faulty
Jun 12, 2009 | HP Color LaserJet 2600n Printer
Color alginment is off
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 20, 2009 | Philips 60PP9202 60" Rear Projection...
AKAI PT5598HDIX, the picture is ghosting
Convergence - many other posts here. A sample: http://www.fixya.com/support/t634294-replaced_convergence_board_picture_still
May 01, 2009 | Akai PT5598HD 55" Rear Projection...
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Nov 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
