Question about Bosch SHU3306UC Built-in Dishwasher
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the bottom
  • Bosch Master
  • 3,361 Answers
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Posted on Mar 26, 2011
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
Water coming back into bosch dishwasher
Check the drain hose that goes into sink cabinet. It should loop up as high as it can go so that water from the sink or disposal doesn't siphon back into dw.
Apr 08, 2015 | Bosch Dishwashers
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher Does not Fill Past First Rinse
There is an anti flood valve on the bottom of the unit. IT could be sticking or have a bad connection. IT should look like a dome shaped housing on the bottom of the tub. If that is not the problem then you are looking at further troubleshooting to see if it is the contoller.
Jan 19, 2014 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Bosch lifestyle dishwasher not filling with water. I undid the bottom and it blew out an air block and started. When reconnected again it is doing the same thing
hey can any1 help me I have a bosch automatic, when I turn the unit on the little fan in the bottom keeps spinning and no water enters the unit, iv drained all the water out of the unit cleaned the drain checked to make sure water is getting to the unit then I pulled the panel off the side and held down this red piece like a float valve down and it then fills with water, but its not completing a cycle, any advice what could be wrong?
Apr 09, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu43c07uc/17 dishwasher
hi check your drain hose is fitted higher than were it joins to the sink. there has to be a loop to stop it back filling.
Feb 13, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU3306UC Built-in Dishwasher Logo
749 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
