Question about Oreck XL2000 Bagged Upright Vacuum
My Oreck 9200 XL will not turn on. It is not plugged. I need to know how to test the switch. I tested it and Ohms and it shows a reading. Is there any other parts I should test. I went around all the motor and there was connectivity.
ukvacfan
  • 328 Answers
SOURCE: oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Posted on Dec 29, 2007
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
SOURCE: XL2525 changing motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=723450
Posted by geoffjackie on Jun 30, 2008
Please forward the wiring instructions for changing the motor in my Oreck XL 2525
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Oreck factory for the wiring instructions but you need to give them the model # and the serial # if needed and I will supply you with the Oreck website and the cust serv phone # listed below. Also, you can check the owner’s manual and sometimes there is a schematic that shows you if information you need for changing the motor. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
  • 206 Answers
SOURCE: My Oreck XL is very dirty inside on fan and the
These units are called dirty air units because the dirt literraly runs thru the fan attached to the motor and is blown into the bag. Most newer vacuums are called clean air because the filter bag is in the path, and the dirt is sucked into the bag, never reaches the fan or motor.
I'd say if it is that dirty, may be a fire hazard, and you may have worn out the seals on the part down at base that pivots to a point that replacement is necessary.
(I'd blow out the dust and keep using if it was me, and then check again in a few weeks, before I replaced. But I like living dangerous.)
Posted on Jul 30, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
My Oreck Xl was working. Turned it off to do other stuff. But the next few minutes whne I turned it on, it didn't turn on. But why?
You've probably tried all this but humor me, check the plug to make sure it's not loose, make sure the terminals at least feel like they're tight and still connected, the walk down the cord (unplugged), hand over hand to make sure there aren't any bulges or shallow feeling spots showing a problem in the wiring.
I would guess there is a fair amount of problems with the foot switch, but I don't know this, after plugging back in, slap the switch with your hand vigorously a few times, if corrosion or a fault is present, this might wake it up, at least give you an idea of where to head next if it tries to run.
Is your cord still retracting as normal?
HTH!!
Feb 28, 2015 | Oreck BB2000 XL Little Hero Canister...
Oreck hand held will not turn on
More than likely, one of three problems. You have a broken wire somewhere in the cord or inside the vacuum. Second, the switch could be bad, third, you have a bad motor. If you have access to a multimeter, you can check all three of those things out by checking for continuity through all parts of the vacuum. Hope this helps!
Sep 01, 2014 | Oreck Vacuums
Do you have wirirng schematic?
this is from a previous fixya answer but is works for the 9100 I rewired my 9100 motor connections like this and now does not blow out the lights and work great
Aug 30, 2014 | Oreck Vacuums
Oreck vacuum repair manual
Unless you have a foot switch, the on/off switch for most Oreck vacuums are up in the handle. You will have normally 6 screws that hold the handle halves together. Take the screws out and then split the two halves apart and you will find the switch inside at the top front of the handle. You may have had a wire come off of the switch and it just needs to be plugged back onto the switch and then you can re-assemble the handle and you should be back in service. If you have a foot switch, you might need a meter to check continuity throughout the vacuum because you may have a broken wire somewhere. Hope this helps you solve your problem.
Jul 20, 2014 | Oreck XL Ultra Bagged Upright Vacuum
The bar on my oreck doesnt turn
1) test the belt drive for worn or broken or crack
2) bearing bar defective.LUBE
3) debris in the bar
4) motor defective repair
see the diagrams.
God bless you
Jul 19, 2012 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL vacuum was goign along just fine and then it turned off. Tried several different outlets, nada. There was not noise or smell prior.
A common problem with orecks is that the cord shorts out as well as the plug. with you model the switch is at the base of the vacuum so it wouldnt be the switch. the best idea would be to take it in to an Authorized Oreck Dealer. I know at my stores we dont charge for service estimates. if it is the cord we could confirm it. but it cost about $50 for a brand new cord and the labor to install it.
Sep 19, 2011 | Oreck XL2200 Bagged Upright Vacuum
Have an Oreck XL upright, when switch turned on no "Power" checked receptical and power supply is OK
What typically happends is if the vacuum falls over the cord will come disconnected from the switch.
there are 6 screws on the handle if you unscrew them the handle will seperate down the middle. you will see a few wires in there. the whites wires should be wire nuted together while the black wire from the long cord, the side that you plug in to the wall, would plug on to the top of the switch, unless you have a 2- speed vacuum the it also would plug into the top but on the prong that is closes to you. it will make sense when you open it up. there is another cord that come up from the base of the vacuum to the handle which is called the up cord. the black wire that comes from that plugs in to the bottom of the switch.
if that doesnt work then you might have a short in your cord that will need to be replaced or your motor could have gone bad. and oreck motor typically last about 8 to 10 years.
if more problems occur i would recommend bringing it to and authorized Oreck dealer. If your vacuum is under warranty it will be fixed for free.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL upright - has a 2 speed switch. Now only works in high speed not low speed. Will a new switch correct or is it the motor
Your vacuum is fine. The switch can either run at full speed or half speed. You are running at full speed, you need a new 2 speed switch. You can pick them up at an Oreck Store for $29 or around $15 on eBay
Jan 17, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Quit working, no power
Most likely culprits, assuming you have power to the outlet you are pluggung into are (1) a bad electrical cord - damaged by bending, tugging on, etc. or (2) a bad power switch. After that, I would check the wires running to the motor.
All of these test require you to open up the unit to properly test. As such, need to be at least mildly acquainted with electrical safety and use of an electrical meter to test continuity.
Sep 17, 2009 | Oreck XL 2250RS Bagged Handheld Vacuum
No Power
try the fuse of course. if that is ok, a likely cause is the mains cable broken usually near the point where it enters machine. if neither of those, suspect the switch or possibly a motor fault
Mar 23, 2007 | Oreck XL Deluxe U3700 Bagged Upright...
Oreck XL2000 Bagged Upright Vacuum Logo
61 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
