The tv is slanted forward when attached to the stand what have I done wrong?
Can you tilt it back on the stand like a PC Desk Monitor?
Is the stand put on backwards?
Posted on Mar 26, 2011
How do I attach the tv stand to a 40 inch Coby television?
This requires some care---set will have to be laid face down--the screen unit or display panel is EXTREMELY fragile---the set must be laid down so the entire frame around the screen is supported and no pressure is exerted on the actual screen! One wrong move or downward pressure can damage/destroy the screen.
The base is attached with several bolts that come with the set--exact length and thread type is critical. They may all be same or different lengths. Line them all up and tighten with hand--snug them down evenly with a tool---NO downward pressure on screen when doing this.
If have lost or do not have the bolts contact the maker who will tell you size, thread type and number of bolts.
Carefully when done lift set upright.
Apr 17, 2012 | Coby TF-TV3217 32 in. LCD TV
40hx800 bravia will not recognize sony 3D transmitter
make sure it is centered and the braces are level
or
Probably the stand is not seated properly into the bottom of the tv.
or
If the image is slanted, an internal adjustment is required.
do vote if it helps ya out
Mar 24, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
I bought a new Vizzio M22OVA and have been trying literally for days to attach the base stand. I even called Vizio customer service and they were no help. I'm at a total loss. I really love the design of...
The stand has 8 small tabs that protrude from the top of the stand. There is also a larger clip that sticks up a little in the center. Purpose of large tab is to snap into place to keep stand from coming off. Just place stand on bottom of tv so the tabs on the stand go into the holes in bottom of tv.
Then just slide stand forward or backward till it snaps into place. I think 2 screws go into the bottom of stand after it is snapped in place to hold it. Just be careful and don't put any undue pressure on the screen. Actually works better with one person holding the tv upside down while another snaps base in place.
Jul 04, 2017 | Televison & Video
TV tilts forward on base about 15 degrees, TV will pivot left or right but won't remain perpendicular or upright.
The only things I could think of causing this would be either the hardware not tightened up properly or defective base (stand.) Make sure all the screws are tightened securely in the bottom of the base and in the back of the tv where the base attaches. Someone may have used the wrong screw holes to attach the base but there really should only be 4 holes to use to screw the base to the tv. This may need returend to the retailer for an exchance of the base.
  1. Oh, the last thing to check is that someone did not put the base on in reverse. Most have a small alightment tab that makes sure the front of the base goes to the front of the tv and if it is put on backwards the tv would tilt forward a few degrees.
Mar 09, 2011 | LG 42LC2D 42 in. LCD HDTV
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I want the forward slant
The forward slant button is the button to the left of the right shift key. Push that button and it will give you the forward slant.
Jun 02, 2010 | Acer NSK8458AN Keyboard
Television tiliting forward on stand on 42LG3000
is the surface that the tv is sitting on flat and level? if you continue to have problems, take it back to the store where u made the purchase or call LG customer service. could just be a bad stand
Apr 06, 2009 | LG 42LG30 42 in. LCD HDTV
The picture Is SLANTED / ROTATED off center!!
Some sets have a coil in front of the deflection yoke to compensate for the Earth's magnetic field and on the back panel there is a slide switch that could have been pushed to the wrong position. Since this is a SONY I'm not sure it has this circuit. It is however worth checking out. I hope this will help you. Stargazer
Jan 07, 2007 | Sony KV-32S26 32" TV
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
