Model ewf1090 electrolux.displays E90 and flashing green lights
  • Washing Mach... Master
  • 822 Answers
Its an electrolux fault code.that means .bad connection on communications wire.this is a blue loom of about 5 wires that come off the main pcb and connect to the display board in fascia panel. clean pcb terminals and tighten loom connection pins and this should solve problem"
wd 40 or another type spray should do it........
cheers
Posted on Mar 26, 2011
My electrolux washing machine ewf1090 after few mins stopped,, any solution plz??
There is too little information to be able to conclude with certainty what is wrong with the appliance.
I suggest that you first check if is there any alarm?
It is possible to read alarm during normal operation (if exist).
The family of alarms is displayed to the user by a repeating sequence during which the END OF CYCLE LED flashes.
You just count how many times the LED diode "END OF CYCLE" light up. That means family alarm code and than we will be able to give precise diagnosis.
Dado
Sep 25, 2015 | Electrolux Washing Machines
I have an electrolux ewf 1090. It started not to spin through a cycle so i unplugged, checked the filters, tipped it on its side to check the hoses, tipped it up right and then NOTHING lost all power,...
Not the belt. you were lucky to get the machine back as laying them on the side allows water from the soap drawer or sump hose to run into the electronics - and the E90 group of codes relates to electronics faults. Your machine will never spin with just one item in it due to out of balance protection - look in your instruction book for the section on out of balance loads - it used to be page 19 lol
Try adding extra clothes to see if it will spin then. If not, could be electronic control panel or motor fault.
Aug 11, 2017 | Electrolux Ewf1090 Front Loader Belt Part...
Hi I have an electrolux front loader model number E/EWF1087/W I switch it on and all the green lights flash and I have an error code reading 'err90'. Can you please tell me what this is and can I fix it...
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Electrolux EW1000i Front Load Washer
My Electrolux EWF1090 is having problems, on the tiny screen it keeps comming up with "E20" i dont know what that means and how to i get it to work?
go to www. Electrolux.com.my/files/malaysia_singapore/manuals/fabriccare/ EWF1090.pdf this will give you the manual with all the information to solve this drainage problem
Nov 14, 2010 | Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
May 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux 1087 E90
When the washing machine is turned on... it beeps and displays error message E90 it wont operate.
what can i do ?
Sep 15, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
429 people viewed this question
Top Washing Machines Experts
