Question about Kitchen Ranges
The machine sounds like a jet during a spin cycle. Seems to be getting worse as the time goes by.
  • stooky1316 Mar 26, 2011
    Yes it was the Washing machine. I don't know why kitchen range came up. Is the bearing replaceable? Is it easy to get at? Thanks
  • 822 Answers
Kitchen ranges dont have a spin cycle.......
if you mean washing machine.... could be main bearing on the drum..........
cheers
Posted on Mar 26, 2011
  • paul
    paul Mar 26, 2011
    easiest way to test for bearing is..............
    open door grab drum edges left and right..............pull and push sideways then top and bottom.......pull and push.
    like you would to test a car wheel bearing......
    if any play then bearing is goosed............depending on machine make and model some are easy..........some are harder.........there shud be some vids to watch on youtube...........just type in machine make and put "bearing replacement"...........
    might be lucky to see how its done......
    cheers
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Machine sounds like it will self distruct when spin cycle begins and seems to try to spin too early in wash cycle
If it is trying to go into a spin during the wash cycle when there is water in it then it sounds like your motor is faulty. The motor has what is called a tachometer in it which regulates the spin speed but if it goes faulty it causes the motor to spin up when it is not meant to. Hope this helps.
Apr 14, 2011 | Whirlpool AWM5125/1 Front Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a Kenmore model 42182 top loading washing machine which makes a roaring sound during the spin cycle. It works all actions during the wash portion so I don't think it is the transmission. I am asking...
your model should begin with a c110 or just 110. it sounds like you have a mounting stem and bearing problem. this can get alot worse as time goes on and is a somewhat costly repair. it involves taking out the entrie tub and replacing the critical center bearing and seal. you can check for fine particles of rubber at the base of the transmission as it has been ground down from the spining cycle of your machine.
Thanks.
Oct 10, 2009 | Kenmore 42182 Top Load Washer
Loud noise during spin cycle
the machine needs to be opened.its the motor problem.the motor has to be replaced. you can get the motor at  www.repairclinic.com
May 06, 2009 | Amana Washing Machines
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Loud noise during spin cycle.
If it sounds like a jet engine and gets louder the faster it spins you have bad bearings and that wont hurt anything. If your using pwder soap that is what made the bearings go out so switch to liquid and it shouldnt get much worse.
Nov 17, 2008 | Washing Machines
Noise
YEA!!!!!! thats a bad rear bearing, depending on age, id call a local authorized maytag servicer and see what they get to repalce it for you, perhaps you still have a part warr on certain parts, otherwise irts not worth the cost of repair
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
