Question about Intertherm Heating & Cooling
I have two Intertherm M1MB 056A BW heaters in need of help: 1: One is flashing five flashes. The label indicates that this would be a reversal of L1 and L2 polarity or no power at L1 (limit switch). It does nothing else. Since nobody has done anything that might reverse the polarity, I am assuming that it is a lack of power at L1. Where is the limit switch and what might cause a lack of power to it? Is this something I can fix myself? 2: The second one starts its cycle in a normal manner except that the combustion chamber fan is getting quite noisy and probably needs replacement. It continues until the flame detector light goes on and immediately shuts down. It will then do nothing until the power is turned off and back on. I can see that the electric igniter is working properly. Having two heaters is nice, except when they both fail at the same time. Given that I am relatively handy and have some experience with electronic circuits, are these problems I can fix myself or is it time to call the repairman? Thanks for your help.
  • 43,501 Answers
Yes there are somethings you can check your self...
On the first one...you are getting power to the board but the board thinks that the hot (L1) and the neutral (N) are reversed or there is not a good ground to the furnace...Use an electrical meter to make sure that the black wire is the "hot" wire and that it goes through the switch and is hooked to the L1 terminal of the board...also make sure that your furnace is properly grounded and also that the electrical panel is grounded properly...this is very important..the L1 does not mean limit... it is referring to the terminal on the main board...
Check page 38 of this for the wire schematic and the note for the five flashes there...
http://www.nordyne.com/Literature/708074e.pdf
On the second one... the furnace is not staying lit because it is not proving that you have ignition...
It could be a bad ground issue also...check that the flame is hitting the ignitor when it lights...the ignitor is also the flame sensor...if the burner ground is bad to the board it will not sense the ignition...a bad furnace ground will also do that...
Also a bad ignito or a very dirty ignitor can also cause that problem...be very careful if trying to clean the ignitor as they are very fragile and can break easily...
I sounds very possible that you have a bad grounding problem and that is the cuase of both problems...they are just reacting to it differently... did both problems crop up at the same time???
Comment back with any questions...
heatman101
Posted on Mar 26, 2011
My nordyne m1 mb 056a bw heater isnt working...a red light flashes twice, which means "Pressure switch is open"...how do i fix it?
First, I am assuming that this is a residential gas fired furnace. 1. The first thing that will happen once the furnace gets a call for heat is the small draft inducer motor will come on. 2. The pressure switch should close. If the switch is not closing, here is a list of possible reasons: 1. The draft inducer motor is not running. 2. There is a restriction in the flue or heat exchanger. 3. The tubing from the pressure switch is not connected or has a leak. 4. The pressure switch may be defective or stuck open. Note: this is not an exhaustive list, but should cover the most common causes. Also, you may have to unplug the furnace and then plug it back in before it will try to come on. It may be locked out on the control board because of the pressure switch fault. I hope this helps!
Nov 30, 2015 | Heating & Cooling
Intertherm M3rl080A BW furnace that shuts down will no indication of fault
If your diagnostic indicator is not picking showing a fault code than it thinks everything is ok with the furnace. It could be a bad thermostat. (or the heat anticipator in the thermostat).
Jan 30, 2014 | Intertherm 56000 Btu Gas Furnace
Just replaced pressure switch on intertherm m1mb gas furnace but still codes "pressure switch open"
CHECK FLUE FOR OBSTUCTIONS AS WELL AS COMBUSTION AIR INTAKE FIRST. THEN CHECK TO SEE IF THE FURNACE DRAIN IS OPEN AND NOT CLOGGED [ONLY IF YOUR FURNACE IS A CONDENSATING HIGH EFFICIENCY MODEL, typically the flue pipe will be 2 or 3 inch pvc pipe] over the years more often than not, it is an obstruction or poor drainage which will not prove the pressure switch to allow the burner to ignite. in rare cases the furnace control board could be bad as well.TRY DISCONNECTING FLUE AND COMB. AIR AT FURNACE JUST TO SEE IF FURNACE WILL IGNITE. HOPE THIS HELPS!!!!!!
Oct 20, 2011 | Intertherm P3RA-048K Air Conditioner
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
I have a Honeywell furnace model #M1MB 070A BW. How do I replace the igniter?
Hello, first turn off power to the Furnace, then remove igniter from bracket and unplug molex connector. Then take the igniter to a Hvac supply store and get new one, reinstall it into bracket plug into molex connector and turn furnace back on.
Mar 05, 2011 | Honeywell Heating & Cooling
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
Heating & Cooling Logo
223 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
