There is most likely a crimp in the line or some other blockage.
Remove the toe kick plate across the bottom front of the refrigerator.
You will see the water line to the door. The pkastic line is about 3/8 inch in size.
There is a plastic coupling that needs to be disconnected.
Have a glass handy and have someone push the water button while you catch the water.
If you get a good stream of water under the refrigerator,the restriction is in the door tubing.
If you do not get good flow,the water valve could be disconnected in the rear and run the water button again.
Ifr you then get good flow the restriction is in the tubing inside the fresh food side.
If you get poor flow at the valve,the valve is bad.
