Question about Dryers
I have a kenmore dryer model no. 11064872401 that won't start. It was working fine yesterday, then just stopped working. The light inside the drum turns on & off, but when I push the start button it won't work. I can hear a click when I push the start button that sounds like it's coming from the timer. I can't figure out what is wrong, because I can't find any fuses or anything in there. Any idea what the problem maybe ?
  • Dryers Master
  • 2,699 Answers
Unplug the dryer,pop off the bottom panel,open the door and remove the lint filter,then go back to the bottom and remove the metal duct that the filter slides into,you'll see the blower wheel.on the top and to the right you'll see a white piece of plastic,with two wires going to it,that's the thermal fuse,pull off at least one of the wires and check it with a meter,if it's bad change it out part number 3392519,if it's good move to the heater box,on the left side of it there will be a couple of thermostats,pull at least one wire off and check it with your meter,most likely it will be the one farthest to the rear,that's the thermal cut off part number 279769,if that's good check the thermostat in front of it that's the high limit thermostat part number 3390291.one of these parts will be bad,just have to check them with the meter for continuity,also while you have the duct off clean it out,also if the vent line is a long run from the back of the dryer to the outside duct,remove it from the back of the dryer and with a leaf blower blow it out,just stick it into the vent line and blow all the lint outside through the vent line,first go outside and make sure the duct is clear so when you blow it out all the stuff will go outside,if anything is on the outside like a cage or a screen remove it,all it does is block lint,this is why one of the parts popped,it's a safety because the dryer was starting to run to hot most likely from a block somewhere in the line or the dryer.let me know how you make out,you're sure there is power going to the machine?if so do the checks i told you about and you should be fine.
Posted on Mar 26, 2011
  • Sal De Mar 27, 2011
    also one more thing to check,open the door,check the door switch,you should see a little paddle that the door hits when it's closed,if that's broken the dryer won't start,let me know how you make out.
Old kenmore dryer, drum won't turn
Could have the motor frozen, (armature,bearings,etc) causing an overload on the circuit. Can you physicly move the drum by reaching in and turning it?
Feb 12, 2013 | Kenmore Dryers
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Kenmore dryer won't start
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
Kenmore dryer model 110.66722692 won't start
does the drum travel up and down losely. if so the spindle at the rear of the drum in the centre has worn and needs replacing
Dec 21, 2011 | Kenmore Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer won't start
The start windings in your motor have gone out. To fix this you must replace the motor.
Justin Duby
T and N appliance Repair
Dec 08, 2008 | Kenmore 63942 Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
