Question about Samsung SpinPoint V60 SV0813H 80 GB ATA-100 Hard Drive
Is a Samsung Spin Point SV0813H compatible will a Dell 3100 Dimension
  • 1 more comment
  • Michael van Brunt Mar 27, 2011
    What would be the jumper poss. on hard drive and what would be the BIOS config
    Master
    It has windoes xp allready on it
  • 2,632 Answers
Welcome to Fixya. Samsung Spin Point SV0813H is compatible with Dell 3100 and it uses a 40-Pin Ide Connector. Please see Dell 3100 Specs Below
Dell 3100 Specs
The image below show how a 40 Pin Ide cable looks like.
If you have questions please let me know. Thanks for using Fixya.
Posted on Mar 26, 2011
  • 4 more comments
  • Rofel Lantican
    Rofel Lantican Mar 27, 2011
    Hi - Would like to know if you will use the drive as a the Master drive or you will use it as a slave?
    Master - Where the operating system is installed
    Slave - Secondary Hard drive
  • Rofel Lantican
    You can use this video as reference on how to set the jumper settings
  • Rofel Lantican
    For the Bios config if the drive will be the master or main drove just select it to be the first priority but then you still need to install a new Operating system on it.
  • Rofel Lantican
  • Rofel Lantican
    will you use a secondary drive? if none then you dont need to put a jumper on it.
  • Rofel Lantican
    If the drive is from a different model of a machine then you need to reinstall the operating system on it because if the chipset of the motherboard is different it wont run.
Dell dimension 3100 desktop
I have met the same problems, just visit Mannualbirds.com to refer to the DELL 3100 manual, your problem will be well solved! View Dell 3100 PDF User Manual Online
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Vga card dell dimension 3100 not identefire for windows 7?
Have you upgraded your OS to Win 7? If so this is a common problem, use the Vista driver found here: http://www.dell.com/support/drivers/us/en/04/Product/dimension-3100 Have you done ALL the Windows updates? Take a look at changing the Compatibility of the driver . Download the driver and Save the file to a folder, Use this procedure to change Compatibility : http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ For further assistance respond to this post.
The top ram slot on my dell dimesions 3100 dosent seem to work. I swaped around the ram cards and both boot up on lower slot but not on top one? Any help? Thanks
Depends on what memory you are using. I don't know any reason that two slots would work and not the other two. Be sure you are using memory sticks that are compatible with each other. Sometimes memory from different manufacturers are not compatible.
Your slots will take up to 1GB each for a total of 4GB.
It takes speeds of 400 MHz and 533 MHz DDR2 sticks.
Feb 16, 2012 | Dell Dimension 3100 PC Desktop
Samsung SV0813H Unmountable_Boot_Volume ERROR
If you recently made any hardware upgrades check that the hardware is fully compatible with your machine.If nothing like that has been done, reboot the pc in safe mode by pressing F5. Some machines are F8. Check your programs and features for any newly installed software or updates. Remove any conflicting software or updates and restart the pc normally.
Oct 31, 2011 | Samsung SpinPoint V60 SV0813H 80 GB...
My desktop computer is done and I need to get the information from the hard drive. It is a Samsung Spin point Sv0813h/TGM. I bought the IDE to USB kit. How do I make it all work?
It is really easy. If your using Windows 7, plug the IDE to USB connector to your Samsung Hard drive. Then using the provided USB cable, plug in the USB cable to the Hard drive. Then plug it into an available USB port on your other PC. Window will automatically install the needed drivers for you. Then navigate to Start/Computer/Local Disk E. Assuming there is no 2nd hard drive or partitions installed. And there will lye your Samsung Drive.
Aug 30, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
How to download pci device driver for dell dimension 3100 desktop
You can found the drivers on Dell Support site for Dimension 3100 Desktop PC thru here.
If you had reinstalled your OS you may have to download Chipset first then second Software Utilities and lastly Video drivers.
Jan 06, 2010 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100- wireless internet
Yes it has. But my best advise or suggestion is to call Dell technical support for assistance for them to set it up. Thank you.
Oct 09, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 won't start.
Check to see if the monitor cable is connected properly.
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
LG Burner installed and wont work
Nero is best software for CD burning and u can choose from market that u like best wishes.
Mar 07, 2009 | Dell Dimension 3100 PC Desktop
Samsung SpinPoint V60 SV0813H 80 GB ATA-100 Hard Drive Logo
80 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
