My prep table is freezing the coil and cold air is not circulating i don't know if the compressor stops after six hours or if it runs 24 hrs in other words it is not defrosting and freezes
    Sergeant:
    Champion:
  • 247 Answers
Adjust or lessen your setting of thermostat. clean yuor air filter
Posted on Mar 27, 2011
Coils freeze
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
Apr 22, 2014 | True Refrigerated Sandwich Prep Table 72"...
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
Jan 17, 2012 | Refrigerators
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
I own a frigidaire model # CF-5D-L*2 manufactured in Feb. 1987 and it stopped cooling off. I've looked at the underside of it and don't see anything off the bat that would be wrong with it. Can you...
Good luck.
Sep 13, 2011 | Frigidaire Freezers
Stopped cooling. fan still runs. after several hours started cooling good again.next morning stopped cooling again
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the model and year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Whirlpool Refrigerators
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ref non-freezing
Is the compressor running? Is the coils near the compressor clean and is the fan that blows on the coils running? Does it get cold at all or is it room temp? One thing to do is to turn it on after leaving it unplugged for and hour. First access the compressor and make sure you can feel the copper lines coming out of it. Some have 4 plus a service pigtail. On the ones with 4 will have two lines the same size that circulate oil for cooling the compressor running to a small set of coils. Pay attention to the larger and smaller lines and notice what temperature they feel like before you plug it back in. Once it is plugged in and if the compressor is running less than a minute the small line should get hot, up to 140 degrees F. Check it soon as after a few minutes it can burn you...The largest of the lines is the low side or suction side and it should be very noticeably cooler than room temp and continue to get colder the longer it has been running. If both these things happen, the charge should be adequate, and the compressor is working. I would then check to see if air is circulating in the unit..Are all the fans running when the unit is on? Most common is for the defrost circuit to fail causing the unit to build up ice behind the liner blocking air flow. Unplugging the unit and leaving the doors open over night will let it thaw. Put several towels around the unit incase this is the problem as there will probably have more water come out than the small pan under neath the unit can handle. Once all the water stops dripping out, plug it back in and see if it works correctly. If so it will probably freeze up again and need to be defrosted again. If so the defrost circuit has failed....either the thermostat in that circuit, the heater coils or the defrost timer switch. Switch very common, coils next and the high temp sensor last.... let me know what you find...
Feb 15, 2008 | Refrigerators
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
