Need to install my new dvd writer on my dell dimension 9200 pc. The plugs are different. now what?
  • 57 Answers
I looked your system up and that system takes serial ata drives. Evidently the new drive you purchased uses the older PATA (also known as atapi, parallel ata, ata-133, etc) interface. This drive will not work in your system. You need to return it and specify you need a serial ata one.
Posted on Aug 04, 2008
If the plugs are different most likely you bought a SATA drive. If your MB doesnt support SATA then there really isnt any use for that drive, i would return it and purchase an IDE drive, chances are thats what you have. Good Luck!!!
I NEED TO BUY A NEW MOTHERBOARD FOR MY DESKTOP DIMENSION 9200 TAG DHGG1C1
Cheapest place to get a new one is ebay just do an advance search for part number on the motherboard ;)
Oct 10, 2010 | Dell Dimension 9200 PC Desktop
Can i burn dvds on my 2350 dell dimension computer if not what do i need
well if u have a dvd burner or a dvd writer installed on ur computer
then u will need to install softwares like NERO or ROXIO on ur computer
first chk, i thnk it mite be already installed on ur computer.
use them and u will be able to burn DVD's
Nov 02, 2009 | Dell Dimension 2350 PC Desktop
Trying to install a dvd writer into a dell dimension 3000. Need to know where find the sound port on the motherboard
There are 2. One directly behind the ethernet port on the board(usually white) one about 3/4 of the way to the rear of the bottom of the board(usually black)
Oct 30, 2009 | Dell Dimension 3000 PC Desktop
My Dell 9200 won't start up (boot) after 7 months non use
No offense, but you need to plug it in to turn it on.
Jun 18, 2009 | Dell Dimension 9200 PC Desktop
I have a HL-DT-ST DVD+-RW GSA-H31N DVD writer It plays CD's just fine. Will not do anything when I insert a DVD. Tried different kind. Go to my computer and it just shows D: I have a Dell Dimension...
Hey there,
Solution:
This problem occurs when your Writer lens goes bad. There is nothing wrong with your system. Just go n get replaced your DVD Writer lens.
Symptom:
It causes so cause your lens has several power regulation. It increases the power as well as decreases the power depends on your layers of your Disc. You might be knowing that your DVD has much more density in space as well as in layers to write than CD. If there are much more depth in the layers a bad lens cannot read the contents.
Gimme Acknowladgement by rating me.
Thanx.
Romy Decostza
Jun 09, 2009 | Microsoft Windows XP Home Edition
Lite On 22X Internal DVD/CD Writer installation?
you will have to go to add new hardware and install it. You will also have to download drivers for it as well.
May 10, 2009 | Dell Dimension E521 PC Desktop
Dell Dimension 9200 "system does not support installed processor
This is really hard to say. Maybe he messed around in the BIOS settings and tried to overclock your processor. First thing I would do is to go into the BIOS (press F2 during startup) and check every setting. You can also reset it to default and see if that makes a difference.
Another possibility is that there is an issue with the RAM. Did you (or he) install new RAM? Look here to find a list of possible issues.
Check Dell's support page, to see if you can upgrade your BIOS.
Check your Device Manager (click Windowskey+R, type devmgmt.msc) for any unusual entries.
That's all I can think of right now. But please come back and post your findings (even if everything looks ok), so we can look into other places.
Apr 13, 2009 | Dell Dimension 9200 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
LG GH22LP20 writer installed into DELL COMPUTER Dimension 9150
Use Master/Slave setup. It makes no difference which drive is in which position, you just have to set the jumper on the drive. Cable position makes no difference as long as the jumper is set correctly.
Mar 30, 2009 | Dell Dim.9150 Pentium D 820 Dual...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
