Question about Ricoh Aficio SP C410DN Laser Printer
SAP jobs are not utilizing the shift finisher
  • lena_ford Mar 27, 2011
    what? you bought a new printer??
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
Kawasaki vulcan won't shift into upper gears above neutral.
Broken selector claw spring
Ride Safe
Bike-Doc
Jan 31, 2012 | kawasaki Motorcycles
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Office Equipment & Supplies
Rebuilt trans shifts 1st to neutral only
It sounds to me like you missed the "shifter knob" on the shift shaft when you installed the transmission back into the case. If your transmission was shifting correctly on work bench, it should at least shift from first to second gear.
You're going to have to pull the transmission back out of the engine case. With the transmission out of the case, look into the the transmission cavity and hold the shift lever so that the short shift arm is level parallel to the bottom of the engine case. Mark the outer end of the shaft so that you can verify that it is still level once you get the transmission back in the case.
Now, put the shift lever (lever you shift the transmission with) temporarily on the shift shaft and support it some way so as to hold it level. Install the transmission. Now, before finishing the installation job, check to see if the shaft is still "level". Install the four bolts that hold the "acess plate" of the transmission in and try to shift through all the gears by turning the mainshaft and having someone hold or turn the countershaft. Make sure the transmission works before you finish up the job.
If the transmission still doesn't shift. Take it back out and work with it in a vise until you figure out the problem. It'll probably be something to do with the shifting mechanism rather than the gears.
Good Luck
Steve
Aug 05, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Wat is sap? its benifits future prospects and from where to do its courses and their fee??
TEKSLATE is Proficient in SAP training which emphasize on hands on experience with examples from real-time scenarios by experts.Register Here and attend for FREE DEMO Please Contact: email : info@tekslate.com website: https://tekslate.com Live Online Training of HANA OBIEE Informatica and Oracle Courses
May 14, 2010 | Computers & Internet
How do I turn off the beep it makes when it finishes scanning?
I donno how to control through software, but by removing the buzzer, you can cut the sound!
Scanners give a beep and they have been designed to communicate even when the operator is not around. Beeps are different for different conditions, from paper Jam to Error to Job finished. Quite an effort goes in designing the beeps, be it microwave or washing machine or Telephone handset. Lets respect the design effort and leave it as it is.
S. Mohan
Jun 05, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Step by step guide to installing sap on windows 2003
hi dear
SAP4.7 Installation On Server 2003 SAP 4.7 INSTALLATION GUIDE 1. CREATE C PARTITION 6GB AND D PARTITION 70GB. INSTALL O.S SERVER. SET SYSTEM YEAR TO 2010 OR 2. CREATE LOOPBACK ADAPTER. START→ SETTINGS→ CONTROL PANEL ADD OR REMOVE HARDWARE→ NEXT→ NEXT→ SELECT ADD ANEW DEVICE NEXT SELECT WANT TO SELECT THE HARDWARESELECT NETWORK ADAPTER SELECT MICROSOFT NEXT NEXT FINISH. 3. CREATE IP ADDRESS MY NETWORK PLACES LOCAL AREA CONNECTION RIGHT CLICK PROPERTIES SELECT INTERNET PROTOCOL (TCP/IP)ADDRESS CLICK ON PROPERTIES AND IN IP ADDRESS 200.200.200. 20 AND OK OK 4. VIRTUAL MEMORY MYCOMPUTER RIGHT CLICK PROPERTIES ADVANCED TAB CHANGE SELECT D DRIVE INITIAL SIZE 2000 MAXIMUM SIZE 2000 CLICK SETOK OK OK 5. COPY ALL THREE DVD IN D DRIVE. SEE THAT D DRIVEMUST HAVE ATLEAST 54-55 GB FREE SPACE. 6. JAVA 1.4 INSTALL [FROM DVD 1] JAVA 1.4 DOUBLE CLICK NEXT I ACCEPT NEXT NEXT NEXT FINISH. JAVA PATH MY COMPUTER RIGHT CLICK PROLPERTIES ADVANCED ENVIORNMENT VARIABLE [SYSTEMVARIABLES ] SELECT NEW VARIABLE NAME JAVA_HOME VARIABLE VALUE ----------- START RUN BROWSE SELECT DRIVE PROGRAM FILES ANDPASTE IN VARIABLE VALUE BOX {Enter Path of JAVA) OK OK OK . 7. ORACLE 8I INSTALL [FROM DVD 3 ] ORACLE 4 NT I386 SETUP ORACLE 8I NEXT NEXT NEXTGLOBAL DATABASE NAME ORA NEXT INSTALL FINISH [ OREXIT] 8. INSTALLATION . [FROM DVD 3] KER NT I386 NTPATCH R3 DLLN DOUBLE CLICK ON THIS PRESS OK. KER SAPINST NT SETUP. SAP 4.7 INSTALLATION SELECT THIS AND PRESS NEXT NEXT SYSTEM ID ----- GIVE ANY DIGIT ALPHABETS [EX: SAI] NEXT SELECT CENTRAL INTANCE NEXT NEXT SELECT LOCAL INSTALLATION NEXT NEXT SELECT C DRIVE NEXT ------- GIVE PASSWORD AS 123 IT WILL ASK TWO TIMES THATPASSWORD NEXT 9. AFTER INSTALLATION OF ABOVE STEP GO TO : \ RIGHT CLICK ON USR SHARING & SECURITY SHARETHE FOLDER IN SECURITY TAB TICK ALL ALLOW. GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ONPREPARE NEW INSTALLATION. THEN AGAIN GO TO PROGRAMS SAP INST ORACLE KERNEL CLICK ON SAPINST SERVE WITH GUI. AGAIN FOLLOWS THE STEP IN STEP 8 WITH THE FOLLOWINGCHANGES. SELECT DATABASE INSTANCE INSTEAD OF CENTRAL INSTANCE SELECT LOCAL INSTALLATION NEXT NEXT SELECT D DRIVE D DRIVE} FOR BOTH OPTIONS NEXT NEXT IN PACKAGE LOCATION GIVE THE ADDRESS OF DB1-----ETC. DB1 EXPORT 1 LABEL.ASC DB2 EXPORT 2 LABEL.ASC DB3 EXPORT 3 LABEL.ASC EXPORT 4 LABEL.ASC EXPORT 5 LABEL.ASC EXPORT 6 LABEL.ASC EXPORT 7 LABEL.ASC NEXT NEXT. SELECT THE OPTION NO MNLS REQUIRED AFTER THIS IT WILL TAKE 15 HRS FOR INSTALLATION. ITWILL SHOW SUCCESSFULLY INSTALLED. 10. GO TO GUI GUI WINDOWS WIN32 SETUP. ã NEXT NEXT SELECT ALL NEXT INSTALL. 11. AFTER THAT CLICK ON SAP LOGON IN THAT CLICK ONNEW ITEMS DESCRIPTION ANY NAME APPLICATION SERVER TO KNOW THISOPEN SAP MANAGEMENT CONSOLE, IN THAT CHECK THE NAME ABOVEPROCESS LIST AND FILL WITH THAT NAME. SYSTEM NUMBER 00 12. CLICK ON LOGON USER ID DDIC PASSWORD 19920706. THEN GO TO SU01 TRANSACTION. GIVE THE USER SAPUSER (this is the user name to logon to sap) THEN PRESS F8. GIVE ANY NAME IN LAST NAME INITIAL PASSWORD REPEAT PASSWORD. THEN CLICK THE TAB PROFILES GIVE SAP _ALL SAP_ NEW & THEN PRESS ENTER & SEE IT WILL ASK THE PASSWORD , THIS IS THE PASSWORD TOLOGON TO SAP, GIVE ANY PASSWORD AND LOG OFF. 13. AGAIN LOGIN TO SAP NEW ID & PASSWORD AND THEN GOTO SE38 AND CREATE A PROGRAM STARTING WITH LETTER IT WILL ASK FORACCESS KEY. IN THAT TYPE 366 87 66 322126 127 8 694. Thank you
Imrna
Pls rank me as possible have nice day
Apr 20, 2009 | Microsoft Windows Server Standard 2003 for...
Bmw air injection pump problem...HELP!
sounds like the secondary air pump has water contamination. If you unplug the connector for the air pump, and check it on cold start, did the noise go away? If the pump is bad, you need to replace the secondary air valve. Sounds like maybe it is contaminated and not seating fully.
Feb 18, 2009 | 2000 BMW M5
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
Sansui DTV2760 27" TV
Since nothing else has worked, are you sure that the SAP function on the Cable Box is not turned on?
Sep 05, 2007 | Sansui DTV2760 27" TV
Ricoh Aficio  SP C410DN Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
