Question about Teac Audio Players & Recorders
I have a Teac Mc-dx50i Shelf System and it won't turn on. I was moving it from one room(playing fine) to another. Set it up, plugged it into the wall socket, turned it on and it will not power up. The light on the sub-woofer does not come on. Help!
  • danefieldjos Mar 26, 2011
    The outlet has power. I plugged in a fan into the same outlet and it works. I have tried more than one working outlet and the unit still will not power up.
    I have power upto the transformer(123v) I don't know how to check the power coming from the transformer. It suppose to be DC 12v.
  • 2,098 Answers
First checked the outlet if it is live by plugging another unit to confirm if there was voltage coming that outlet. Let me know if it has a power.
Jdvillanueva
Posted on Mar 26, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva Mar 26, 2011
    Checked the continuity of the power cord for open internal wire (this is due to frequent bending and pulling) with an ohmmeter. Once confirmed that the power cord is good, open the cover of your unit to check the internal fuse if blown (sometimes it was caused by power surge or aging). If blown, replaced it with exact voltage and current ratings. Let me know if your unit still didn't power up.
    Note : before opening the cover, check if it is under warranty, if so don't open, it will void the warranty.
  • Jdvillanueva
    The output of transformer is AC voltage. Best way to check the voltages is across the largest electrolytic capacitor in the power supply (DC voltage). This capacitor will give you an idea of the voltages that you are going to checked by reading the working voltage of it (If rated 50V in its body, you will get below from 50vdc.)
  • danielledh8 May 29, 2011
    I have same exact problem, moved unit from one room to another and it won't power up. Was this problem solved?
My teac mc-dx50i subwoffer wont turn on and its even plugged in
About all you can do is to make sure it has power and input from the main system. Past that, the amplifier in the subwoofer is most likely damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 08, 2013 | Teac Audio Players & Recorders
No power to Teac-MC-DX220i
it seems you power unit of mc-dx221 system got burnt just open your system and see the power unit
May 30, 2012 | Teac MC-DX22I Shelf System
Have moved and lost owners manual. where can I get another one?
http://teac.com/resources/pdf/mc-dx32i/MCDX32_B_OM.pdf
Feb 28, 2011 | Teac MC-DX32i Shelf System
The remote(RC-1185) for my DX 50i has never worked
www.remotes.com Remote model # RC-1185 $53.95
Aug 27, 2009 | Teac Mc-dx50i Shelf System
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Mar 23, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
Jan 18, 2007 | Teac MC-D95 CD Shelf System
333 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
