Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Refrigerator and Freezer lights do not work and all display lights are not working either, but fridge and freezer are working.
    Scholar:
  • 116 Answers
Hi i'm sean I work for GE as an employee, this is a bad control board located in the rear of the refrigerator behind an access panel, you will want to change this as soon as possible it will possibly cause damaged to your sealed system on this model if prolonged in that condition. The board usually runs between 175.-200.
Sean
Posted on Mar 26, 2011
Samsung RF25HMEDBSR bottom freezer fridge. Fridge is at right temp.,ice maker works, but the bottom freezer is not working.
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator/freezer becomes less efficient, causing it to work harder to cool down. If the coils are significantly dirty, it will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty. All models have coils in an enclosed area usually accessible via a vented cover at the back of the refrigerator. These coils help to keep the refrigerator and freezer cool. If these coils become too dirty from dust or other particles, the freezer may not work as efficiently.
unplug when taking the vent panel off to clean. bottle brush or a vacuum attachment be careful not to bend aluminium fins.
Jan 30, 2018 | Samsung Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
The fridge part is not working freezer fine. N the display setting lights keep flashing. It's a hotpoint future fridge freezer
I don't know about all the flashing lights. but if your refrigerator isn't working, but the freezer is, It is usually your cooling fan is not working
Jan 08, 2013 | Refrigerators
My NEW GE side by side fridge died today!
The display off because your power board is faulty. (Under gaurentee i hope. Need to call the warrenty repair guy out.
Sep 21, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
156 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
