Question about Kitchen Ranges
Will the door of a Whirlpool microwave Model MH1141XMQ 0 fit a Microwave model MH6140XKQ
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 09, 2008
  • 136 Answers
SOURCE: our Whirlpool 27" Built-in Combination
This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q-- My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
also look for this electric wiring chart given in this link below just click on the link
http://www.applianceaid.com/image/microflowchart.JPG
thanks.
Posted on Oct 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: damaged inner seal tape on whirlpool microwave door window
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Whirpool burned - model #mh6150xhb-0
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
jyackle5
  • 8197 Answers
SOURCE: Need microwave glass door replacement
http://www.mdappliance.com/WPL-W10206726.html
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=1946925
Here are 2 sites that have it. The second site has in stock in alabama ready to ship.
Good Luck and Please Rate FixYa!
Posted on Feb 25, 2009
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
MISSING OWNERS MANUAL FOR MODEL gh4155xpq-0 Microwave
Do you mean the Whirlpool Microwave Hood Combination GH4155XPQ0? Most Whirlpool appliance manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . The direct link to the manual for the GH4155XPQ0 is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208204919.pdf .
Sharp doesn't have a microwave with this model number. If you gave the incorrect model number but the correct manufacturer, please add a comment with the correct model number.
I hope this helps.
Dec 03, 2011 | Microwave Ovens
My whirlpool microwave MH6140XKQ 2001 turns on but won't heat up and the tray dosen't spin ???Ideas
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Whirlpool Ovens
Feb 25, 2009 | Microwave Ovens
Plastice door covering and handle
htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Roper Microwave Ovens
Whirlpool mh1141xmq
Unplug the thing, open it up, and carefully take off the pad button controls and anything else with wrong behavior, and wash those things out with dishsoap and deionized water.  It seems like a pad switch has saltwater or sugar in it, or crumbs pressing on it.  The door and main switch often need cleaning out also, though compressed air or cotton swabs (no excess water) will be fine.  Then put it back together, plug it in, and try it.
Jun 29, 2008 | Whirlpool MH1141XM Microwave Oven
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
