Question about Maytag Neptune MAH5500B Front Load Washer
Water won't drain from washing machine
After I run a load and full cycle there appears to still be water in the machine. It does not appear in the drum but when I turn the drum I can hear it sloshing around.
  • 5 more comments
  • snappy_pants Aug 05, 2008
    I also have water left in the drum after spinning. I have gone through every test in Service Mode with no problems. Leaving water there to get stagnet and moldy can't be good.
  • maxschnell Aug 06, 2008
    Ditto.  I also looked at the rubber surround the drum and small amount of
    water collecting there has turned to rust.
    I never noticed before but I am getting divorced and doing my own laundry and quickly noticed that I heard water somewhere.
    I guess I will contact Maytag tomorrow.
  • macyjack Aug 11, 2008
    I have the same problem. Washer does the load but there is still water when I hand rotate the drum. I always wipe the inside seal and reserve area...but problem is still there in the drum. I took off the back panel (removing the 4 screws)..but there isn't a release valve like the Kenmore has. NOt sure how to remove the water.
  • sunrisetk Sep 28, 2008
    so Maytag says it's designed this way to keep balance when spinning?? I guess the stench and the mold is by design also... I want my money back!!
  • gdperrin Sep 29, 2008
    Water is always in the machine, when you wash a load of cloths you have to be right there to get them out or they will stink and you have to rewash them. I don't see why this water is not drained completely out and fresh water used every time.
  • Anonymous Nov 07, 2008
    I have the same problem no mold or stink yet thank god. This maytag was in my home when i bought it and i will NEVER buy another product from maytag or any of their associated companys again!
  • Anonymous Nov 16, 2008
    washer works perfect but clothes its wet
The water or liquid you hear when you spin the drum is not from washing it's suppose to be there to balance the spinning of the drum.
Posted on Sep 11, 2008
I have a similar problem with a Maytag Performa. I'm going to take the drain hose off and remove the pump to clean it out and then re-install it. Vinnegar does cut through the soap build up...but you have to get it WHERE the soap build up is! Hope this helps
deb from Illinois!
Posted on Jan 11, 2010
I have the same problem except my machine actually stops every minute through the last spin cycle. I called sears repair twice and the last time the repair man came said that I was using too much detergent and not the right kind. So I had a soap build up. If I was using the right kind, I only needed a tablespoon of the detergent per load. I don't have the mold buildup as of yet. He suggested leaving the lid up when not using it so it dries out. He said that I just needed to work it out and that it may take 1-2 months of washing properly. He also suggested that I use vineagar(?) in an empty wash cycle at the end of the day to help it dry out.
Well, it's been a week and my machine still doesn't work right. But I have a warranty with SEARS until March 2009. Why can't they clean any build up when they have the machine taken apart?
I hope this helps.
Posted on Nov 14, 2008
We have the same problem with our neptune. We also have mold build up on the seal. Maytag doesnt want to help and says we missed the recall!! I will never buy maytag again!!
Posted on Aug 08, 2008
We've had the Maytag Neptune for 8 years. I also hear what sounds like water in the drum even after the machine is finished and has gone through the spin cycle properly. While we did have some minor mildew buildup in the detergent cup area, we never had it in the drum area. We leave the door open between every cycle and we've taken out the removable bleach/softener dispenser and we also leave the door up on the detergent dispenser area between every cycle. We've been following these practices for the past few years and have never had a smell nor a recurrence of significant mold/mildew growth.
Posted on Nov 16, 2008
I have a GE Eterna top loader washer. It appears that is not spinning during spin cycle (damp clothes and softener not dispensed). Spin cycle runs with no load. How can I troubleshoot further?
Perhaps you machine is full of water and therefore restricted by the excess water in the tub, perhaps try draining the machine first then try again. it could be that your pump in ineffective .
Sep 19, 2016 | GE Washing Machines
How do I fix my washing machine? It doesn't appear to feed enough water into the machine. The machine runs through a full cycle but appears low on water even in the middle of a full wash cycle.
I can try to explain the difference between today and the old washing machine. My question would be, are you satisfied with the washing result? If so, then everything is fine.
There are four factors that affect the washing and they make one single round (duration, temperature, mechanical action, chemical action). Old washing machines are spending more water, more detergents, more electricity power, and consequently more spoiled environment and duration of washing was app. from 1 to 1.5 hours. Today washers use less water, less detergent, less energy power, less polluting but because longer duration of washing cycle app. from 2 to 3 hours, wash result was the same as in the old machine.
I think that today confuses people how is possible that washing machine wash three hours (longer than before) and consumes less energy? Believe me this is true, and every service tehnician will explain it.
Because old habits many customers put the same amount of detergent (do not read the manufacturer's instructions) and therefore have problems with the skin. That is why an increasing number of washing machine has the option of additional rinsing cycles.
Dado
Jul 23, 2015 | Bosch Washing Machines
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Water draining?
It depends on the brand they all set things up differently now. Check with the manufacturers specs to see what is supposed to happen and when.
Cheers
Al
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Washer still full of water
There is a water level indicator that might be clogged,or the timer isn't working properly,either way if you take the timer housing apart you might find a schematic to locate the parts inside the rest of the machine
Apr 27, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
740 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
