Question about Tek Nek Toys Audio Players & Recorders
Not working on my computer after disk was installed
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
Dec 02, 2014 | Samsung R530 Notebook
Disk boot failure insert system disk
First if your computer has a floppy drive, check to a floppy drive does not have a floppy disk in this drive.
Your computer cannot find the hard disk to boot up.
Go to your BIOS to see if the BIOS detects the hard disk, if not remove the hard disk and re-connect it again and see if it boots up.
If it still does not boot up then most likely the hard drive has failed.
To get the computer working again, install a new hard drive, install Windows and the computer's device drivers and your programs.
Dec 10, 2010 | Computers & Internet
Product key
Assuming you mean the product key for Windows, the product key should be on a sticker, usually on the bottom of the laptop. It is probably 25 digits mixed numbers and letters. You should have the disk it came with to install it - sometimes the product key will work with a disk from a different computer, but if the setup disk and your key are different versions it will not work. An example: If you do not have the original setup disk your computer came with, and your computer has XP home and you borrow a disk from someone but it is XP Pro, your number will not work. If your original disk was for XP home and it was with SP-2, (SP = Service Pack) a disk without SP-2 will not work. Plus, the original disk(s) usually came with the drivers you will need to reinstall Windows. You would be pretty lucky to install Windows and not need to download drivers to finish installation. Original setup disks from the manufacturer are not that expensive, and save a lot of time and frustration.
Nov 10, 2010 | Microsoft Computers & Internet
Think Point!!!!!!!!!!!!!!!!! All these solutions sound nice. The problem is that even in "Safe Mode with Networking" I cant access anything on the computer that includes the start menu. So I cant install...
One way:
* remove the disk-drive from your computer
* install a different disk-drive (any old, 4GB or larger, disk-drive will work)
* install Windows onto that disk
* install anti-virus software onto that disk
* reconnect the previous disk-drive as a "slave" disk-drive
* launch the anti-virus software, targetting that "slave" disk-drive
* shutdown
* disconnect the different disk-drive
* boot from the original disk-drive, now that it is virus-free
Oct 19, 2010 | Computers & Internet
Can not read disk error
You can't install any hard disk from any computer and install it into your computer and expect it to work unless it came from the same model computer with the same devices that are installed on your computer.
When Windows is installed it configures the operating system unique to that computer and stores this info in the Windows registry.
To get a used hard disk to work in your computer, you have to install Windows as a fresh installation on your computer.
May 16, 2009 | Gateway Solo 1450 Notebook
Cant install program from DVD drive GWA-4164b
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
Oct 26, 2008 | Computers & Internet
Mother board or CpU Doesnt work. technician said I have a ghost inside my CPU!
verify your bios settings with regards to what the pc is expecting in way of hard drive.
Do you have the luxury of another hard drive that you can try on this pc ? - this will 'suggest' where the problem rests.
Make sure the lead is fully located on the back of hard drive.
If possible - change the lead for a 'known working' lead (Maybe from the computer that your hard drive was recognized in)
Aug 15, 2008 | Seagate (ST307504FPA1E3-RK) Motherboard
Creative Zen mp3 player - computer won't recognise it
The ONLY AND I REPEAT ONLY way to solve zen and computer recognistion problem is to have THE ORIGINAL INSTALL DISK that came with player.
The only things that will work is
1. Download Utorrent 2. Go to google or yahoo and search Creative (you'r player type ie zen touch, zen mossiac, zen x, etc.etc.) install disk torrent. 3. Try to find the one that is closest to the name of your player (ie. zen touch, mossiac, x) and download the install disk. 4. After the download finishes you should be able to run setup like you have the disk.
I downloaded the install disk torrent and after i finished downloading I simply found the setup file clicked it and installed the neccessary files, and presto my computer recognised my zen touch.
#2 If you can't find a install disk for you perticular player, you should try to see if maybe a friend or someone youknow has a creative mp3 player and ask to borrow there install disk, who knows it just might work for you'r player. Best of luck and I hope this will solve you zen player/computer problem
Jul 17, 2008 | Creative Labs Zen Touch MP3 Player
Trying to downgrade to Xp
Sounds like you need to boot from the disk.Put the windows XP disk in the cd rom turn the computer off then turn it back on.The computer should see the disk and boot from it.Follow the prompts.You cannot downgrade if you are trying to run the installer after you computer has already booted,but you can load the operating system if the computer BOOTS from the XP disk.
Nov 15, 2007 | HP Compaq nx6310 Notebook
Top Tek Nek Toys Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tek Nek Toys Audio Player and Recorder Expert? Answer questions, earn points and help others
