Question about Kenmore HE3T Washer
F21coming on front - Kenmore HE3T Washer
  • 822 Answers
Press the "Stop" button twice to cancel the cycle and unplug the washer "F21" could be a blockage ... check the drain hose for kinks, and clogging with ****... and try the cycle again.
cheers
Posted on Mar 26, 2011
Center console removal
Well, this good to be interesting to say the least, and probably long as well. By my gm. service information your going to need to take out the front bucket seats so the sides of the console can come off.
Remove the left front seat . Refer to Bucket Seat Replacement .
Front Floor Console Extension Panel
Retainer Clip (Qty: 5) same for right side.
showgif.do?image=1875475
Callout
Component Name
Preliminary Procedure
Remove the right front seat. Refer to Bucket Seat Replacement .
Front Floor Console Accessory Trim Plate Assembly
Procedure
Use a flat bladed plastic trim tool in order to release the console accessory trim plate from the console assembly.
Retainer Clips (Qty: 5)
Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement.
Front Floor Console Accessory Housing Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
2 N?·m (18 lb in)
Front Floor Console Accessory Housing Assembly
Procedure
  1. Disconnect the electrical connectors.
  2. When replacing the front floor console accessory housing assembly, transfer all necessary components
  1. Remove the rght or left front floor console extension panel. Refer to Front Floor Console Extension Panel Replacement - Right Side or Front Floor Console Extension Panel Replacement - Left Side .
  2. Remove the front floor console cup holder housing. Refer to Front Floor Console Cup Holder Housing Replacement .
Front Floor Console Rear Trim Panel Screw (Qty: 1)
Tighten
2 N?·m (18 lb in)
Retainer Clip (Qty: 4)
Preliminary Procedures
  1. Remove the front floor console accessory trim plate. Refer to Front Floor Console Accessory Trim Plate Replacement .
  2. Remove the right and left front floor console fillers. Refer to Front Floor Console Filler Replacement .
Front Floor Console Armrest Assembly Bolt (Qty: 4)
Tighten
9 N?·m (80 lb in)
Procedure
Position the armrest assembly out of the way leaving the electrical harness attached.
Front Floor Upper Console Trim Plate
Procedure
Lift the rear of the trim plate first, releasing the retainers securing the trip plate to the console assembly.
Retainer Clips (Qty: 4)
Front Floor Console Replacement (Enclave)
showgif.do?image=1858392
Callout
Component Name
  2. Remove the right and left front floor console extension panels. Refer to Front Floor Console Extension Panel Replacement - Right Side and Front Floor Console Extension Panel Replacement - Left Side .
  3. Disconnect the automatic transmission range selector lever cable. Refer to Range Selector Lever Cable Replacement .
Front Floor Console Screw (Qty: 2)
Tighten
2 N?·m (18 lb in)
Front Floor Console Bolt (Qty: 10)
Tip
Before installing the right lower forward bolt, ensure that the console wiring harness is tucked below the fastener location to avoid driving the bolt into the harness.
Tighten
9 N?·m (80 lb in)
Front Floor Console Assembly
Procedure
  1. Note location and routing of the front floor console wiring harness prior to removal of the front floor console assembly to ensure proper reinstallation.
  2. Disconnect the electrical connectors.
  3. With the aid of an assistant remove the console assembly from the vehicle.
  4. When replacing the front floor console, transfer all necessary components.
h4hqqpweof7+aaaaaelftksuqmcc
arzs+0tf0j6faaaaaelftksuqmcc
Jan 10, 2015 | 2008 Buick Enclave
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
Aug 23, 2014 | 2010 Harley Davidson FLHTCUTG Tri Glide...
How you take off the front bumber
have 96, 95 similar
Section 01-19: Bumpers 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Bumper and Bumper Cover Front
Removal
  1. Raise and support the vehicle.
  1. Remove the RH and LH front wheel (1007).
  1. Remove the RH and LH front fender splash shield screws. Remove the RH and LH front fender splash shields (16102).
  1. Remove the four front fender brace screws.
  1. Remove the two front fender brace nuts.
  1. Remove the two plastic screws.
  1. Remove the seven clip buttons located under the front bumper cover (17D957).
  1. Remove the RH and LH front turn signal lamps (13369). Refer to Section 17-01 for the removal procedure.
  1. Remove the four front bumper cover brace bolts.
  1. Remove the front bumper cover from the vehicle.
  1. Remove the two front turn signal lamp wire harnesses from the front bumper (17757).
  2. Remove the eight front bumper bolts.
  1. Remove the front bumper from the vehicle.
Mar 02, 2010 | 1995 Mercury Villager
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
Fallen driver's side window
probably need a new window regulator. ebay. 93 to 98 should fit.
Section 01-05: Trim, Interior 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. swv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942) .
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel .
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screws from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124) .
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure.
Window Regulator, Power Front Door
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Remove the front door window glass (21410) . Refer to the front door window glass removal procedure in this section.
  1. Remove the two front door brace bolts and the front door brace.
  1. Disconnect the front window regulator electric drive electrical connector.
  1. Remove the four front door window glass regulator track bolts.
  1. Remove the three front window regulator electric drive bolts.
  1. Remove the front door window glass regulator track and the front window regulator electric drive (23394) as an assembly through the opening in the front door (20124) .
Installation
  1. Install the front door window glass regulator track and the front window regulator electric drive as an assembly through the opening in the front door .
  1. Install the three front window regulator electric drive bolts. Tighten the front window regulator electric drive bolts securely.
  1. Install the four front door window glass regulator track bolts. Tighten the front door window glass regulator track bolts securely.
Apr 29, 2009 | 1998 Mercury Villager
I am trying to get the wheel assembly apart to change the front bearings on a 1996 mercury villiger
http://groups.yahoo.com/group/villagerquest/
Item Part Number Description 1 — Cotter Pin 2 — Nut Retainer 3 1131 Insulator 4 3B477 Front Axle Wheel Hub Retainer 5 1195 Front Wheel Outer Bearing Retainer Washer 6 1104 Wheel Hub 7 1107 Lug Bolt 8 3K050 Snap Ring 9 3123 Front Wheel Bearing 10 2K004 Front Disc Brake Rotor Shield 11 3130 Front Wheel Knuckle
Wheel Hub, Wheel Knuckle and Wheel Bearing SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Tie Rod End Separator T85M-3395-A
Removal
  2. Remove the wheel (1007) and tire assembly.
  3. NOTE: It is not necessary to disconnect the front brake hose (2078).
    Remove the disc brake caliper (2B120) and suspend it with mechanic's wire out of the way. Refer to Section 06-03 for the removal procedure.
  4. Remove the front disc brake rotor (1125).
  5. Remove and discard the cotter pin.
  6. Remove the nut retainer and insulator.
  7. Remove the front axle wheel hub retainer (3B477) and the front wheel outer bearing retainer washer (1195).
  8. Remove and discard the cotter pin from the front suspension lower arm ball joint (3050).
  9. Loosen the front suspension lower arm ball joint nut until it contacts the front wheel driveshaft joint.
  10. Strike the front wheel knuckle with a hammer while pulling down on the front suspension lower arm (3078) until the front suspension lower arm ball joint separates from the front wheel knuckle.
  11. Remove the front suspension lower arm ball joint nut.
  12. Remove the front suspension lower arm ball joint from the front wheel knuckle.
  13. Remove and discard the cotter pin.
  14. Remove the tie rod end nut.
  15. Use Tie Rod End Separator T85M-3395-A to separate the tie rod end (3A130) from the front wheel knuckle.
  16. Remove the front brake anti-lock sensor bolt.
  17. Remove the two front shock absorber-to-front wheel knuckle nuts.
  18. Remove the two front shock absorber-to-front wheel knuckle bolts.
  19. Remove the front shock absorber (18124) from the front wheel knuckle.
  20. Use 2-Jaw Puller D80L-1002-L, or equivalent, to separate the front wheel driveshaft and joint (3B436) from the front wheel knuckle.
  21. Remove the front wheel hub, front wheel knuckle and front wheel bearing as an assembly from the vehicle.
  22. If necessary, match mark and remove the steering stop bolt and steering stop bolt jam nut from the front wheel knuckle.
Installation
  1. Position the front wheel hub, front wheel knuckle and front wheel bearing as an assembly on the front wheel driveshaft and joint.
  1. Install the front wheel knuckle into the front shock absorber.
  1. Install the two front shock absorber-to-front wheel knuckle bolts.
  1. Install the two front shock absorber-to-front wheel knuckle nuts. Tighten the front shock absorber-to-front wheel knuckle nuts to 113-123 Nm (83-91 lb-ft).
Apr 10, 2009 | 1996 Mercury Villager
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Kenmore HE3T Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
