Question about Bose 901 VI Main / Stereo Speaker
Bose 901 Equalizer connections to Harman Kardon AVR520
Would you kindly tell me exactly which connections on the back of my AVR520 for the equalizer in/out? Thank you.
  • Anonymous Nov 27, 2008
    I have the same problem. I have connected the Bose 901 speakers to Harman Kardon using the Bose Equalizer. Howvere, I have connected the Bose to the FL and FR channels - however, it seems that the other channel sound gets filtered out. Can/ Should I connect additional speakers to other channels? If yes, how can I find compatible speakers?
    Brigadier General:
  • 8,546 Answers
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
If your receiver has Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Posted on May 16, 2009
Best way to hook up Bose 901 series VI to a Harman Kardon HK3490
According to the HK site, "Stereo pre-amp outputs let you connect the receiver to an external power amplifier." So it's easy. Connect the Bose equalizer in the pre-out / amp in loop.
Nov 07, 2015 | Bose Audio Players & Recorders
Recently I bought a Harman Kardon HK 3770 Stereo receiver. My question is " can I use a Bose 901 Series VI speaker with this receiver?, since I plan to buy a 901 S VI speaker.. The receiver has no tape...
From the description of the Harmon Kardon, it sounds like you should be able to use the speakers, but you will not be able to use the active equalizer. The equalizer is designed to be cabled into the tape monitoring loop and allows you to listen to the equalized signal coming back into the receiver. Attach the +/- speaker wires to the right and left channel speaker connectors on your receiver.
Jan 15, 2015 | Bose Audio Players & Recorders
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
AVR 1600 receiver won't connect to bose series III EQ
You mean BOSE 901 Series III Active Equalizer; and HARMAN KARDON AVR1600 right?
Sure it will. It goes in a Tape Loop such as Tape Out/In or Video 1 Out/In. But it won't work for anything except analog stereo sound sources as all digital audio is not available to the RECORD OUT jacks when the Tape or Video 1 is activated. AND 901 Active EQ is intended solely for 901's, not any other speaker system
The HK has no Line Level volume-controlled Pre-Outs so you're out of luck if you want the 901's to take part in a multichannel setup, which would require a separate power amp to drive them anyway.
Aug 23, 2011 | Audio Players & Recorders
How do you hook up the Bose 901 series VI to a Harman Kardon AVR 510 receiver?
Search Fixya for the dozens of times I have answered this type of question. The central theme is you will need a separate power amp for the 901's and use of the Pre-Outs.
Aug 22, 2011 | Bose 901 EQ1915 Home Equalizer
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer '
    Jan 03, 2011 | Bose Audio Players & Recorders
    I have a Harmon Kardon AVR 247 and I want to connect with Bose 901 VI equalizer. No other speakers are connected, just the 901's. Where do I connect the wires from the equalizer to the AVR 247...
    I have this exact setup. 901s are my Mains.
    The AVR247 has PreOuts on all of the channels.. No jumper to remove either. Just get a power amp or two and place the 901 EQ between the AVR247 and the Power Amplifier.
    Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
    Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
    Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $ might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
    Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
    Satellite receiver and DVD player out to Radio Shack audio/video selector
    Audio/video selector out to VCR in.
    VCR video directly to TV
    VCR audio red/white (audio) out to equalizer
    Equalizer out to Receiver Tape IN (Receiver Out not used)
    Hope this (or a variation of it) helps.
    Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
    Bose 901
    1-record out from receiver to to equalizer in.
    2-equalizer out to tape pb in receiver.
    Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
    Bose 901 VI Main / Stereo Speaker Logo
    1,176 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
