Question about Garden
We need to replace a pump for a small pool/pond that's at the entrance of our house. It goes from outside into the house. We had a plumber here to fix a leak that it had, and he said to replace the pump first (which he doesn't do). Is there a service we can hire in the Orange County/San Bernardino County area of California?
  • 794 Answers
Hi en_bratsj,
You may refer on the details below where you can get a service for your pool/pond pump replacement.
J and C Pool Service
905 E Carson St #5, Long Beach, CA 90807
T: 310-890-3182
(Serves Orange County and entire Southern California)
GRG Pool and Spa
14071 Peyton
PO Box 1802
Chino Hills, CA 91709
Toll Free: (888) 955-3456
Local:(909) 606-6042‎
(Serves both San Bernardino and Orange County)
Hope it helps.
Thank you for using Fixya.
Posted on Mar 26, 2011
Why is the pump pulling water but blowing air as well as water in the pool?
look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
May 08, 2014 | Pentair "Pentair" In Ground Pool Pump ...
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
Has Leaking noise very audible on hotwater line but no flood in the house or outside the house, and the water meter records unusually high. Three certified plumbers checked the house but could not find...
First, find out if you have a leak.
Turn off all water faucets inside and outside.
Record water meter register with camera.
Wait several hours.
Record water meter register again, and compare photos.
If you have a leak, contact city water department and report leak so bill can possibly be adjusted.
Ask city water department what they suggest.
If you had certified plumbers look at problem, it would be a guessing game for internet plumber to start listing things.
My guess would be crossover on single-handled faucet that runs the hot water into cold pipe that is filling the swimming pool that is leaking. But you might not have a swimming pool.
http://waterheatertimer.org/Crossover.html
Another guess would be a leaking TP valve that drains directly into a sewer vent line.
But certainly the plumber checked the TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Add a comment and say how the problem was solved.
Sep 24, 2011 | Water Heaters
The jacuzzi magnum force pump can it be used for a fish pond
This is a lot of pump for a fish pond. You should use the safe-guards as you would find in a pool, two drain's separated by 3 or so feet and/or a couple skimmers. You dont want the fish getting pulled into the drains/skimmers. It will also be a lot of $ to run the pump compared to a smaller 'fish pond' pump ... of course your pond may be much larger than the average garden variety.
Personally, I dont think this is a good idea for a small pond. Tell me more about your pond.
Thanks for your question @ FixYa.com
Jul 08, 2011 | Jacuzzi Magnum Force Series Pool Pump 1...
I CAN NOT GET PRESSURE TO MY SAND FILTER i KEEP TRYING TO PRIME IT BUT IT HAS NOT WORKED i HAVE A hAYWARD S 240 AND A Vari flo I'm just opening my pool on Aug 7, 10 it always happen when we open the...
There is a air leak somewhere between the pool and the inlet to your pump --- probably the connection going into the pump housing from the pool. Put plumbers putty around the joint. Keep checking until you find the leak and the pump actually draws a suction. The impeller is sound, right? If not, replace it and the seal between the motor and the pump housing.
Aug 08, 2010 | Hayward SAND FILTER, PRO SERIES
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Where dothe hoses go
Suction from the pool goes into the front of the pump housing ... Discharge from the pump goes to the filter. If multi-port, there is a suction and a discharge port identified. If it is push/pull, Top port goes to waste, center is water in, bottom is water return to the pool.
Pool water is suppose to go into the top of the filter and out the bottom for return to the pool.
When manipulating the valfe (multi-port or push pull), ASSURE the pump is OFF! If multi-port valve, only turn the handle clock-wise.
May 16, 2010 | Hayward Sand Filter System & Tank 21" 1...
I have a Hayward Northstar 2HP pool pump. I need
If the motor still runs at all start the pump with the lock off and it will pop out. If not use some liquid soap and a small straw like a capalery tube on wd. Any thing small enough to fit through the space you can get when you pull the seal plate back, their is an inner plate with an "O" ring and you need to get the soap to that then let it sit for half hour or so and go back to the side to side prying when the soap and the "O" ring come together it will slide right out.
Sep 20, 2009 | Hayward Northstar Dual Speed Max Rate 2 Hp...
Punp leaking water think around barrins
You need to change your pump seal. It goes on the shaft of the motor as it enters the rear housing of the pump. If it has been leaking for a while,and started to get really loud you might want to replace the motor while you got it apart.
Apr 03, 2009 | Sta Rite Sta-Rite Super Max In-Ground 1.5...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
