Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
    Brigadier General:
  • 3,911 Answers
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Posted on Mar 26, 2011
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Battery is not holding a charge
it does have a low amprage charging system under the flywheel
May 31, 2012 | Garden
Battery doesn"t charge
I don't see how this is related to the float?
With the engine running, measure output voltage from the alternator/charger at the battery. It should be about 13.5 vDC. It should increase a little bit with higher revs. If voltage doesn't change with engine running vs. engine off then you probably have a bad alternator which probablly has to be replaced or repaired by a service shop.
Jul 18, 2011 | John Deere 420,1020,2010,2020,2510,2520...
My mower discharge when the blades are ingauge
The wires connected to your PTO are the key to your problem. The electric pto is designed to run off the engine charging system when it is engaged and will run your battery down if it isn't. The fact your battery will charge and hold a charge tells me it is probably ok. You will need a wiring diagram to figure this out. You might check outdoordistributors.com. They have pdf files that you can view online for most lawn tractors. Good luck Tim
May 31, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Battery won't hold a charge. I have to jump it with my car.
There are lots of things to check here. 1st is the battery getting a charge after the engine is running. If it is getting a charge then I would recommend putting the battery on a charger to bring it up to a full charge. Then if it loses the charge again the battery will need to be replaced.
Nov 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
727 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
