Question about APC (APNBE725BB) UPS System
Backup not working when power off. First started blinking red battery light. Checked the battery still 13.5 v ?
  • 591 Answers
This may sound silly but are you connecting your appliance on the correct side of the UPS??? one side of the UPS is for SURGE protection only, (NOT battery backup), the other side is for SURGE and BATTERY BACKUP protection, I'm asking because a lot of people did that mistake... if you have than the other mistake a LOT of people do is they don't connect the battery wire (when the unit is shipped the POSITIVE wire is disconnected) so the battery doesn't drain... if every thing is connected according to the manual and it still not working than use the calibrating software to check the state of the unit and calibrate the UPS, than refer to the company that sold it to you if nothing works it might still be under warranty...
Cheers!
Posted on Mar 26, 2011
  • Tommy
    Tommy Mar 26, 2011
    don't forget batteries will some times hold the correct voltage wen checked with a meeter but not with a load...
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
APC SUA1500RMI2U Smart-UPS . the led blink with red after the test button . it is indicated with cross. continuously blinking & no green indication shown . but ups is running
Hi Juhi,
You may need to replace your batteries. Have you checked battery voltages?
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 07, 2014 | APC (SUA1500RMI2U) (0731304197300) UPS...
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Have a ultra vision 70vs810 it blinking red and
I tried all of the above and no luck but THEN we realized we had it plugged in to the surge protector not the battery backup. Once we plugged it in to the battery backup it powered up like a champ! Good luck!
Jul 31, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
The battery backup side is not working other side works
Its most likely caused by a dead, failed battery or a bad connection with the battery inside the unit.
Double check the connections inside the unit to ensure the battery is connected properly. If it is, take a volt meter and measure the strength of the battery. A 12v ups battery should read about 13 volts.
Mar 27, 2010 | Computers & Internet
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
APC (APNBE725BB) UPS System Logo
214 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
