Question about Maytag Dryers
The clothes don't dry well - Maytag Dryers
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Mar 27, 2011
Not drying efficiently. Air moving ok, heat appears to be ok. Would like to open it up to visually inspect it. With event off slight burning smell. Would like to verify clean of lint.
If it tumbles and it heats up but your clothes don' t dry disconnect the vent tube from the the wall and run a load of wet clothes if they dry then your homes venting is clogged and if it still does not dry then it could be your thermal fuse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
Mar 30, 2014 | GE Dryers
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2012 | Frigidaire Dryers
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
My dryer turns on filter is clean but clothes do not get dry what is the problem?
90 percent of the time when clothes don't fully dry its due to the vent being clogged or obstructed, check the vent tube and the access vent on the outside of the home.
Jul 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I push the button to dry my clothes and it is still damp. The dial has a 30 minute side on each side. It is a new machine. I'm used to setting the dial one time and my clothes are dry.
Make sure you don't have the vent kinked or stopped up with lint. Sounds like your dryer may be overheating. The vent connects to the back of the dryer and pipes to the outdoors.
Apr 13, 2011 | Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
