Question about GE Profile JTP18 Electric Single Oven
The start button is not activating the oven - do i have to change the whole board
    Scholar:
  • 116 Answers
HI, you need to change the whole front keypad not the board. This piece is about 150-200.00.
Sean
Posted on Mar 26, 2011
All buttons work except 'start'.. do i need a key panel
Given the start button is the most used, it is the one that most often fails first. The key panel is one unit, but sometimes you can clean to fix button by removing panel to access and depending on button, some are simply pressure sensitive, so look for sticky button and make sure it operates the same as others. Otherwise, you will have ot replace whole panel.
FREE-PPV.com
Jun 03, 2015 | Ovens
My double ovens do not work unless I keep the buttons pressed in the whole time I need for cooking, when I let go the ovens go out?
YOU NEED A NEW CONTROL MODULE, THAT PANEL IS A COMPUTER BOARD AND DOES BREAK. EITHER FROM HEAT EXPOSURE OR CLEANING SOLVENTS
Dec 05, 2014 | Stoves 720EF Electric Double Oven
Oven light does not turn off?
Door switch bad or not activated some ovens have a on button on control board that will keep it on. model posted is a diswasher
Jul 15, 2014 | KitchenAid Architect II Superba EQ Series...
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
GE Profile Wall Oven Circuit Board
http://www.searspartsdirect.com/partsdirect
I HAVE QUESTIONS. THIS THERE 240 VOLTS AC TO OVEN. YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH 3-5 TIMES FAST TO GET IT TO RESET. IF THE LAST THING YOU DID WAS A SELF CLEAN THEN YOU MAY HAVE A SAFETY THERMOSTAT PROBLEM. IF YOU CANNOT FIND THE WHOLE MODEL NUMBER ON THIS SITE CALL 1-800-GECARES THEY WILL HELP YOU WITH PARTS
Apr 25, 2010 | GE Profile JTP18 Electric Single Oven
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Built-In Oven Buttons Stop Working
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
Email me for some pictures:
schmidtkeith1@yahoo.com
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Up/Down buttons don't work
This would usually need a keypad replacement. It may come as a whole console or as part of range control board. From what I see in pictures, it appears to be an insert panel that goes into console assembly. Looks to run about 200 dollars. You will need complete model and serial numbers off oven to order correct part. These parts are usually not returnable.
Nov 22, 2007 | Amana AOCS3040 Electric Single Oven
Ge oven jtp18 broiler mode
Mine started doing this also. It is the "F7" error reported elsewhere, and it means a bad board or bad connections. I'm in search of a diagram or something to tell me how to open the face up and look at the contacts to the board.
Mar 21, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
50 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
