Question about Watches
I have a marea digital watch it has 4 buttons around the casing top left is reset bottom left is mode top right is st/stp and bottom right is light I have tried to reset the clock without success can you help please.
SOURCE: Changing the time on an LCD Digital Watch
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Malcolm S
Posted on Aug 27, 2008
SOURCE: Watch
Hold down the mode button and it should start blinking on the seconds. If not the mode, then the adjust button, but hold if down for a few seconds. Then if it was the mode button probibly the adjust changes the time, if the adjust , then the mode button should adjust the time. I don't know if it just adjust the seconds and then you have to move to hours and then min and so forth, but if you do just try the st/stp button. Tell me if this works, it should but if not I'm here to help. Good Luck!!!!
Posted on Jul 09, 2008
SOURCE: How to set a Joe Boxer wrist watch
I too have the same problem and have decided that the best solution is just to go to Kmart, the outlet for all Joe Boxer products; and tell the lady at the jewelry counter that you cannot find a manual for your Joe Boxer watch. She likely will be happy to let you see a manual and may even have a spare or can at least help you get one. If she is as friendly as the ladies at our local, she may even copy one for you, if a copier is available. You could also bring a digital camera with you that is of fairly good quality and take pictures of the manual.
Posted on Aug 28, 2008
SOURCE: Armitron WR165 watch - changing time
it works!!
Posted on Oct 29, 2008
  • 5 Answers
SOURCE: How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
Posted on Apr 21, 2009
How to set the time in titan zoop c3001pv04
I am sorry but the time cannot be changed. But there is another option in which you can not see the date. Press mode button or the bottom left button until display shows T2 in the bottom left side. Press Reset button or the upper left button. Thus will make the hours number blink. Set the time using ST/STP button or the upper right button. To set the minutes, press Reset button or upper left button and the minutes number will blink and set it using the ST/STP button or the upper right button.
Dec 02, 2014 | Watches
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
How do I set the time and date on my Aquasports Solar Power watch?
The AquaSport watch? The one with the digital panel instead of hands? Push and hold the bottom right button (Reset) to get to the start of the menu. Use the bottom left to advance the modes and the ST/STP upper right button to change a display, such as time.
Truly unintuitive, but fun watch. If you're a masochist.
Jun 20, 2010 | Watches
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Thanks!!
Oct 06, 2009 | Bulova Watch
WATCHES
i hope this helps....
the top right says st/stp....tells you the year
the bottom right is the light...
the top left is the reset....
and the bottom left is mode...alarm, stop watch,and time 2
Oct 29, 2008 | Watches
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
Malcolm S
Feb 29, 2008 | Watches
Watches Logo
857 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
