Car Audio & Video Logo
Posted on Mar 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have recently had a battery change on my renault, and now my cd player (wharfedale) wont come on. the power button is glowing red, but when i press it, it doesnt switch on now more
Sid Schmidt
Level 2:
Sergeant:
Champion:
  • Expert 218 Answers
  • Posted on Mar 26, 2011
Sid Schmidt
Expert
Level 2:
Sergeant:
Champion:
Answers
218
Questions
Helped
44225
Points
614
It probably is the antitheft system for the radio that requires a code be input into the radio to resume functioning whenever the radio loses power. You will probably need to contact the dealer to get the code for your particular car
Wharfedale boombox , pressing volume button the sound does not increase, please help
Are there any "parental controls", that define a maximum volume?Are you sure that your speakers are plugged-in, powered, and working?
tip
Wharfedale M5 DVD Region Free Fix
Wharfedale M5 DVD Player Region Free Fix
Would you like to unlock your Wharfedale M5 DVD Player to Region Free?
Follow these steps to unlock your Wharfedale M5 DVD Player:
  1. Press the Setup button on your remote control.
  2. Press the buttons 6, 2, 8, 3 and then 6 on your remote control.
  3. In the Regions Setting - Factory Menu page, set a specific region or choose All for Region Free playback.
  4. Press the Setup button on your remote control to exit the menu.
Your Wharfedale M5 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 • Televison & Video
My renault clio 1998 r reg key fob wont work
hold the cetral locking lock all button down until the doors lock and unlock. The imobilser light goes solid red. At this point you have 10 to press the botton on your key 2 times . the doors will unlock and lock.
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
6helpful
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
V reg laguna alize radio code wont work
CAN U TELL ME WHATMAKE OF CD PLAYER IS IN CAR & ARE U ABLE TO REMOVE UNIT & MAKE A NOTE OF SERIAL NO.
2helpful
2answers
Car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Wharfedale dab radio da-110e
According to the manual the indicator lights go out when the batteries are charged.
2answers
Wharfedale L19T11W-C (hack codes)
Get in contact with a Wharfedale authorised dealer to do this one. It requires a Blackberry interface, and specail programming, if this set will accomodate the change...accordianman
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
