Question about Neovo F-417 17" LCD Monitor
I have a neovo f 417 and the vga cable is kinda broken and the screen will sometimes turn yellow. if i bend the cable, the monitor works normally again but its a lot of work to do that and get the monitor to work so im wonderin if its possible to replace the ingrated vga cable. if it is, can you please give steps on how to replace the cable.
sandrew
  • 2961 Answers
SOURCE: Neovo F-417 failure
You may need to set your laptop to send the video signal to a secondary screen, this will be done by right clicking on the desktop and clicking on graphics properties. Some laptops have a presentation mode on them it may well be there also.
Posted on Jan 29, 2007
  • 4 Answers
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
Posted on Feb 17, 2008
mavreix
  • 63 Answers
SOURCE: My Neovo f-417 LCD Monitor is switching off after
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Posted on Sep 23, 2009
  • 293 Answers
SOURCE: Neovo F-417 monitor keeps switching
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Posted on Oct 05, 2010
SOURCE: Please ? i need shematic diagram for monitor NEOVO
jais un probleme avec mon monitor lcd nuevo s17 ,il s'allume et l'écran ne s'affiche pas c'est quoi la solution a se probléme
Posted on Dec 31, 2010
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
Why does moniter keep saying check video cable when turned on it is connected right
It is quite common for new flat screen monitors to report this as computer boots up. If it comes back on each time and continues then just ignore it. PC's switch the video output on and off as they power up. This is normal. New monitors are just impatient. Ian.
Sep 18, 2011 | Neovo F-417 17" LCD Monitor
F-417 Neovo monitor only works in safe mode. Can this be fixed?
Can you please clarify the problem? It works if you start the computer in safe mode but not in normal mode? Do you get the message like 'out off range", "format not supported"?
Mar 18, 2011 | Neovo F-417 17" LCD Monitor
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Mar 07, 2011 | Neovo F-417 17" LCD Monitor
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
My Neovo f-417 LCD Monitor is switching off after 3-4 seconds. Green lamp is still blinking but there is no ligts and picture on screen. Only black screen
Sep 23, 2009 | Neovo F-417 17" LCD Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
F-417 working inconsistently after power fluctuation/outage.
You may want to check the VIDEO cable that goes from the monitor to the computer. Make sure its in tight. If the montor still continues doing this, it could be caused either by A) a faulty monitor, or the monitor is going bad B) the video card inside the computer is going bad. If you have another monitor in the house, try it and see if you have the same problems. If you do it's most likely the video card inside the comptuer going bad. If you don't, then replace the monitor. Was the monitor plugged into a surge protector? Let me know how it turns out... THANKS
Dec 20, 2008 | Neovo F-417 17" LCD Monitor
Neovo F-417 failure
Jan 29, 2007 | Neovo F-417 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
