Question about Frigidaire FD38HONGDC (NG) Grill
Igniter doesnt work - Frigidaire FD38HONGDC (NG) Grill
  • Frigidaire Master
  • 43,501 Answers
Follow the wire from the ignitor back till you find a black box...inside that box there is a battery that needs to be replaced...
heatman101
Posted on Mar 27, 2011
I bought a new ignition, 2 keys, for a 1997 Honda Recon. The new ignition doesnt work and the old ignition now doesnt work. What can I do?
check the main fuse line. if you did this with the battery on it will blown the fuse. inturn dead ignition.
May 23, 2018 | Honda Cars & Trucks
2005 PONTIAC MONTANA KEY IN IGNITION SECURITY PROBLEM
if the car does not start and the security light is on maybe check out this site.... I have bought a part from them and it fixed my issue.. if u r unsure email them they have great customer service.. also ifn its what I think it is you can install the part yourself
Jul 27, 2014 | 2005 Pontiac Montana SV6
TANSMISSION
My 1997 Z71 did this twice last Summer. PRNDL indicator didn't work, Tach, Speedometer, didn't work. Only 1st & 3rd in auto Trans worked. Fuse for all this wasn't getting any power. Replaced ignition switch. Fixed problem.
Feb 06, 2014 | 1997 Chevrolet K1500
My truck just died when i was driving it.all my guages quit working and now the wipers dont work glow plug doesnt light up..horn doesnt work but headlights do and it wont start
Offhand I would say that the Ignition Relay or Ignition switch is bad. You will not be able to start a cold diesel without the Glowplugs. If you think about what works and what does not work when the ignition key is not turned on, many of the things match your problems.
If you lost your Ignition the truck would stall and just quit. Usually the headlights would still work. The Wipers would not work without the Ignition being in the ON position. Not sure how your horn is wired but most Honk with the Ignition in any position.
Now there is a difference when you say it won't start: whether you mean it does not crank or that it cranks but will not start. If the Ignition is working-the Glow plug Timer should cycle, but it will need power from the power Relay. So when you turn the key you should hear the timer.
There can be a Master power fusible link. It should be near the battery. You can go register your truck at Autozone.com and get free wiring diagrams.
Please comment on my info.
Apr 05, 2013 | 2004 Ford F350
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
THE RIGHT REAR ELECTRONIC IGNITER DOESNT WORK
All of the igniters are connected together. When power is applied they all get activated and all burners spark. If one aint working either the ire to it is off, or the igniter have grease on it and therefore cannot get a good ground, or the hole beside the igniter is clogged and thus the gas won't ignite. This first video shows how they work and the second one is very important because it shows how to keep from damaging the stove while attempting repairs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 08, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Security light flashing and ignition doesnt work
your ignition switch is bad for now though turn your key on for at least ten minutes until the light stops flashing this will reset your security system after stops flashing turn key off and then start the truck
Mar 17, 2009 | 1999 Chevrolet S-10 Pickup
Frigidaire FD38HONGDC (NG) Grill Logo
79 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
