Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
Hello what amp breaker is required for the 2340 ingersol-rand compressor?
  • 89 Answers
SOURCE: Starting problems
IF YOUR PRETTY SURE DRAW A CAPACITOR WIRING DIAGRAM AND THEN TAKE YOUR CAPACITORS TO ANY MOTOR SHOP OR SUPPLY HOUSE LIKE WW GRAINGER. THEY CAN CHECK THE MICROFARRADS OR UNIFARRADS OF YOUR CAPACITORS. YOUR START CAPACITORS HAVE THE LARGER MF OR UF RATING AND ARE TYPICALLY LARGER IN SIZE. YOUR P.O.S. INGERSOL RAND MAY EVEN BE A 3500 RPM MOTOR AND COULD HAVE UP TO 5 CAPACITORS. 3 OF WHICH ARE START. IS YOUR WIRE LARGE ENOUGH? IS YOUR BREAKER LARGE ENOUGH? IS YOUR COMPRESSOR UNLOADING THE HEAD PRESSURE WHEN IT CUTS OFF? IS IT OUTSIDE AND TOO COLD IN THE MORNINGS? MAKE SURE YOUR WIRING IS LARGE ENOUGH BECAUSE THAT IS USUALLY THE PROBLEM. YOU HAVE SINGLE PHASE BUT IS YOUR VOLTAGE CORRECT 208V OR 230 V. ALL WIRING AND GAUGING CHARTS ARE BASED ON 100 FT OF WIRE . MOST COMPRESSORS PULL 3 TIMES THE AMP RATING ON INITIAL STARTUP THEN COM DOWN TO AMPS LISTED ON THE MOTOR.
Posted on Jan 27, 2009
Idaho_Biker
  • 32 Answers
SOURCE: service of ingersoll rand
Actually not a lot of Parts.
1) Remove & Clean the Air Intake Element
a) Check and see IF the Secondary Pump Head has a Filter/Breather and Clean That also...
2) Drain and Change the Oil (per Manufacturer Requirements-I PREFER Ingersoll-Rand Compressor Oil Myself) Don't Over-Fill!!
3) Check the Wear on the Drive Belt(s) and Tension ( Deflection shouldn't be more than 5/8" Between the Motor and Compressor)
4) I usually Blow out the Motor with about 20psi of Air, since it probably has Sealed Shaft Support Bearings, and is the Brushless Type, Not Much to do. Pull Off the Inspection Plate, and Check for How Clean the Inside of the Motor is BEFORE you "Air-it-Out", if there are any signs of Greasy Dirt, you may want to get some Electrical Spray Cleaner, and spray just enough to Wash the Contaminants off...
5) DRAIN Your Main Holding Tank: Drain Until there is NO Moisture Left, just Dry Air. You could Drain into a Pint Mason Jar-Just make Sure you Only Open the Drain just enough to let a Minimal amount of Flow, and see what Contaminants are in your Tank...(this should be done at least Once a week anyways) I installed a Auto-Drain on Mine, AND a Auto Water Drain on the Regulator is a Great idea too...
6) Check ALL your Wiring Connections, make sure they are Tight...Vibration will cause them to Loosen.
7) Sometimes is a Good idea to Check Your Keyways on Your Pulley Shafts for Wear, should be a "Press-Fit"
8) Check the Pulley/Belt alignment, make sure it's running True. IF Not, Check Your Motor & Compressor Mounting Bolts
I usually do a PM (Periodical Maintanence) about every 3 Months on My Compressors...and don't forget to Oil Your Air Tools Before each Use.
Posted on Jan 31, 2009
darjr
  • 378 Answers
SOURCE: wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
  • 1388 Answers
SOURCE: How do I adjust shut off pressure on an Ingersoll
The best way to go about the task of adjusting the pressure switch is to remove the cover to switch and note the brand/model number. Sometimes instruction are under cover of switch. With switch information, look for mfg. instructions. You will most likely see one or two springs with lock nuts. Do not turn them yet. Most pressure switches are sold with factory adjustment and are sold in pressure ranges. For two stage compressors as yours, the pressure is usually factory set at much higher (150-175) pressures than single stage which is usually about 120 -125. If you change the pressure setting it will also change the differential cut on pressure. The factory will actually use different springs to achieve desired pressures and are color coded. There are too many different brands of switches to recommend how to change pressure setting. You may discover that you can only change the pressure just a small amount (+or -15-20psi ). If you find the information about your switch, make sure that you count the turns exactly so that you can return to factory settings if things go wrong. You can extend the life of the comperssor by lowering the pressure as more amperage /heat is produced to achieve higher pressures. Good luck
Posted on Sep 23, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
What size breaker for 5hp motor? Ingersoll Rand T30 242-5d 1988
If its a 220vlt compressor a 60 amp twin breaker is recommended. good luck!
Aug 08, 2011 | Ingersoll Rand Compressors 5-HP,...
Won't build air pressure & piston rings seem to be ok
Did you inspect lp and hp valves. I would take a close look at the HP valves first,typically bad Lp valves will cause it to build pressure very slowly.
Jan 31, 2011 | Ingersoll Rand 2340/2475 Electric Air...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Nov 14, 2010 | Ingersoll Rand 2340/2475 Electric Air...
Ingersall-Rand T 30 Model 2340 Motor overload trips when trying to fill air tank. How long should it take to fill the tank with air with tank empty. If tank is full it may cycle one time when using air.
You need to know the size of the tank before you can figure pump up time from empty to full. It sounds like you have a bad tank check valve. A bad check valve typically causes the motor overload to trip when starting.
May 21, 2010 | Ingersoll Rand 2340/2475 Electric Air...
My IR 2340 air compressor wonr drain with the auto
its most likley to be blocked with muck take it off and give it a good clean
Oct 22, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Pressure falls to under 80psi before restart
thereshould be an adjustment inside the control box once you take the cover off it is self explanitory you can raise or lower the cutin cutout pressuresto suit your requirements
Jul 26, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Starting problems
Jan 16, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
64 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
