Question about Globe Antique Beige Ocean Mova
It quit rotating - Globe Antique Beige Ocean Mova
My Sunbeam mixmaster quit spinning on bottom where the bowl sits
Does the bowl table rotate freely by hand? If not, it may need a squirt of spray lubricant. If the table rotates freely by hand but doesn't turn when mixing, look at the bottom of your beaters. The beater that is closer to the outside should have a nylon button at the bottom. This nylon button rotates the bowl as it turns. If the button is worn or missing, you will need to get new beaters.
Aug 18, 2016 | Sunbeam Food Mixers
Will not rotate
You need to check the manual. try here
ceiling fan manuals
Dec 14, 2013 | Tower Aloha Breeze Fan
Blurry picture, focus
Can't you rotate the ring around the lens to focus it.
If it does move sometimes you have to rotate it quite a few times left or right.
Feb 15, 2012 | GE MiniCam Pro HO98756 Webcam
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No Rotation
it should unless your model stops the drum for rack dry. More than likely your motor quit or your belt broke
Nov 04, 2009 | Computers & Internet
Augers quit rotating.
I would assume either the spring on the clutch are bad or worse yet the bronze gear in the bottom end broke loose from the shaft.
Jul 05, 2009 | Ryobi Cultivator
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
Service tire system, what does that mean???
Well, it might simply mean they wish to rotate your tires. When you are told your tires need to be rotated, it means your tires are warn on certain parts. You can get quite a few more miles out of the tires if you simply rotate, or move the front right to another place on the car, and change the rest of the tires positions as well.
They might also want to just check to see how warn they are in general, but their likely going to rotate, and align your tires.
Apr 16, 2009 | Chrysler Pacifica Cars & Trucks
No drum action from my Bosch Maxx for Kids
Hi, How old is your maxx? Have you ever experienced this before?
This is quite a common problem and can be sorted quite cheap to. You will need to take the back off depending on which model you have to access the motor! Take the motor off and then we can sort the problem.....
Get back to me....
Mar 07, 2009 | Bosch Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Globe Antique Beige Ocean Mova Logo
43 people viewed this question
Top Globe Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Globe Toy Expert? Answer questions, earn points and help others
