Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Mixer leaked come oil
My sister passed along to us a used KSM90. She commented that she thought it had leaked out some oil, possibly not being stored upright for a short time. I don't see any mention of oil in the instruction booklet and haven't tried to dig into the unit yet, but see oil residue around the head pivot area. Any advice?
Thanks.
Dave R
  • Ron Forstad Sep 26, 2008
    i have oil leaked from around rotary beater, it is a kitchenaid ultra power mixer, it has only been stood on a worktop, i moved it and there was a little puddle of oil, any idea's!!
  • rjdebellis Oct 17, 2008
    There seems to be oil leaking from under the head and drips onto the counter. Not much, but leaking oil on anything is generally a bad sign.
  • KitchenAid Master
  • 19,396 Answers
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Posted on May 28, 2009
I have oil leak from Kitchenaid standmixer, what should I do?
Where exactly is the oil leak coming from? Comment back to this post.
Apr 22, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have lost about 20ml oil from my Kitchen Aid KSM90 mixer. Is it necessary for me to replace it? Is it possible for me to replace it? What sort of oil?
I would suggest that you replace the oil, but first find out the reason for the leak. There must be a cover on a gearbox that can be removed to put oil in as I doubt that there will be and actual filler point on the machine.
Jan 16, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Leaking oil from drive/mixer head
There could be one of two things wrong (or both). You might need a new seal or you might just need the machine to be regressed. Also, never keep your mixer stored on its side as this will automatically allow the machine to leak grease.
Nov 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer is leaking oil. How do I fix it?
Your mixer is leaking grease not oil. It is a simple fix. First you have to open the machine and regrease it. Once you have done that try replacing the gasket. Also, this particular mixer cannot be left on its side (some people store it sideways in a cabinet or under the sink) doing so will cause the machine to leak as well.
Oct 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer was turned upside down during move some oil leaked out should I have it repaired
YES..... It's a KitchenAid... it's worth putting a little money into, and you want to guarantee that everything is in tip, top shape. I had mine fixed 15 years ago.... it was 8 years old then, it is still working great!! It is worth it and will last..... who knows? I'll probably pass this down to my daughter!
Aug 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I have a KSM90 that is about 8 years old. It started leaking oil and the top of the mixer goes down into the bowl too far and it 'drags' the attachment along the bottom of the bowl and makes a generally...
It sounds like the Planetary Gear assy. has gear lubricant leaking into it from the gear case above it. This may not be that unusual so there may be 2 possibilities or a combination of both. The Gear Case is directly above the Planetary Gear assy. It is filled (sort of) with a food grade (assuming...I hope) grease that is necessary to keep things lubed. There are fiber washers and possibly an o-ring in the shaft assembly which should keep the grease from migrating toward your food. The Planetary Gear assy. is the part that rotates around on the business end of the mixer. It has a bronze bearing that is intended to run without lubrication. However it is a wear point and if worn sufficiently, could allow escape lubricant from the gear case above to drip into your mix. The Kitchen Aid Service Manual is a good source of info. You can get it as well as complete diagrams of the internal parts at:
http://www.goodmans.net/get_item_ka-4162075_kitchenaid-mixer-4162075-planetary.htm
You can also get parts and the KitchenAid Service Manual.pdf at:
http://www.mendingshed.com/kitaidparts.html
I know if it was my mixer, I'd give it a look. They're good tools and worth the effort!
Good luck.
DZII
Jan 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Oil leak
Hi, W3HAL ? How much oil are we talking about, and over what period? How old is your machine? Your KA mixer?s internal gears are factory packed with enough grease to last a 'lifetime' (whatever that means). Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it?s been used; these factors all will eventually cause grease?s base oil to separate from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 4 & 5, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Your transmission case gasket is Illus. # 18, which you might want to reorder for starters. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My Kitchen Aid is leaking oil slightly from the bottom. What should I do? How do I add more oil if it needs it?
That is food grade grease separating. Pick some up at an appliance parts store. You may have to split themotor housing to add it if it has no point of greasing.
Oct 26, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
289 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
