Question about HP Officejet 4110 All-In-One InkJet Printer
Printed align page but message on printer screen still ask me to place align page in feeder.
    Guru:
  • 89 Answers
It could be stuck on error message that may lead to possible hardware issue for HP Officejet 4110 All-in-One Printer
But after it printer alignment page put the page facing down to the scanner glass if your printer has one
If not then its an automatic alignment sensor issue inside the printer maybe the reason
call hp support 18004746836 they may give you options to upgrade you unit to a newer version with a low cost
this is only exclusive for HP customers you can take advantage of it
Solving Print Cartridge Alignment Problems
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&cc=us&lc=en&dlc=en&product=90792&tmp_track_link=ot_search
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Posted on Mar 27, 2011
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
I have a 5610 all in one printer and when I just put in the new cartiges it gives me an error message stating "Cartige not aligned".
Issue
The instructions displayed on the computer screen during the Print Cartridge Alignment are incorrect. If the printed alignment page is placed on the scanner glass and the Scan button is pressed as instructed on the computer screen, the all-in-one will beep and the control panel display will indicate Busy . The all-in-one will not align the print cartridges.
Workaround
The instructions on the printed alignment page or the all-in-one control panel display are correct. Follow the instructions below: Place the alignment page on the scanner glass and then press the OK button on the all-in-one to complete the print cartridge alignment.
Mar 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
  5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
Print function
The printer prints alignment page; after enter button.
Place the printed page in scanned glass properly.
Press the scan button and wait untill the ON light stops blinking.
Now alignment is completed.
Regards,
Riztech
Mar 02, 2010 | HP PSC 950 All-In-One InkJet Printer
Same Deal here and no help
Reinstall and follow the setup. when asked for alignment place paper in paper feeder. place the printed page on scan tray properly. once scanned it is done.
Sep 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printer Dell 964
There are some peculiar printers. These need alignment prior to first printing. If u havn't done it, reinstall the printer, during setup one stage it will ask for alignment, the place a plain paper on the feeder. A printed page will come out, place it on the scan tray (be sure of placing it properly with correct directions). It will be scaned and a success signal will appear. thats all.
Sep 04, 2009 | Dell Photo 964 All-In-One InkJet Printer
Saying "enter to align cartridges continuously
You need to press the enter key on the top of the printer to start the alignment. On some of these devices you will need to place the printed alignment page face down on the scanner and then hit the enter key so that the printer can read the printed alignment page.
Dec 29, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
OfficeJet K60 All In One Problem:Aligning Cartridges
In the process of alignment there are two phases:
1. When the message comes to align the ink ..press ok and the page is printed out.
2. Once the page is printed then place the page on the scanner glass and tehn scan the same.
Follow these two steps in the same order and it will never give Align Ink Cart message again.
Oct 24, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
