Question about Mackie 1604 Vlz3 16 Channel Mixer
I have a Mackie CR1604 that hasn't been used for several years. When plugged in, a hum results on all channels, some channels louder than others. The hum gets louder as the sliders increase. Is it worth fixing and are there any techs in the Boston area that can handle it? Thanks, Bill
  • 4,234 Answers
This should be a fairly reasonable repair. The main problem is finding the source of the hum. Since it is effected by the sliders, the source is in the mic pre-amp sections. Since all channels are effected, I would suspect a power supply problem rather than a problem with the electronics. Please send a note to Lauren@fixya.com asking her for contact information for me. I can help you out. These are decent mixers (I own a few) and should last for many years. Yours just needs a little TLC.
Dan
Posted on Mar 27, 2011
Testimonial: "Dan's answer was extremely helpful. "
Hum when mixer is turned on
If it is a 60Hz or 120 hz hum, the fault may be a bad solder connection to a filter capacitor in the power supply.
If it is a hum like a bad mic connection, you may have dirty contacts on an input, dirty tracks on a mixer control, even on the EQ portion.
It may also be a bad cable is connected, or a 1/4 inch jacked input may not be grounding out when the plug is removed. You may have a bad ground on the power feed and you have a ground loop as a result, or a cable is faulty and creating it's pwn ground loop to something else.
Contact cleaner is not a bad idea, slide pots are notorious for spurious noise over time. LPS1 is not bad, but it does use silicone as the dry lubricant portion.
If all of that is ruled out, look internally for bad solder joints- anything that looks crumbly is suspect, and also check for loose wires and jacks with bad solder connections. Also look for loose connectors too.
Mar 29, 2012 | Mackie 3204VLZ3 32-Channel USB Mixer
When I connect the Mackie 1642-vlz3 from the "direct outs" to the line level inputs of the D3200 there is noise/hum (except for channel 1). There is no noise/hum in the XLR inputs. I have two...
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Jun 01, 2011 | Korg D3200 Digital Studio
A 16/4 channel Mackie VLZ bought new 1997 hardly used. Some times a channel goes quiet, sometimes the fault moves to another channel, or while setting a channel input signal the knob seems to work till...
I suspect you MAY have a severe ground loop. The green light indicates channel crossover if nothing plugged in.
MAKE SURE ALL connected equipment is powered from the SAME receptacle. If you service amps from receptacles at one end of the room and this board from the other end, you are ASKING for trouble.
Read up on "common mode" as it pertains to balanced lines. Equipment can be at risk if grounds "bounce" as they often do.
When green light with no inout shows up, slide all faders down first. Then unplug input lines one at a time... turn off the amps and then unplug the output lines one at a time. See if one of these inout or output lines was causing the green light.
You should be using BALANCED lines to your amps... either XLR or TRS types at both ends.
May 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie CR1604 has a consistent click at hi gain
Without hearing the noise or seeing it on a scope, I can't say for sure, but this type of noise can come from a number of sources. If there is a high signal level on one bus, you could be getting some cross-talk from that channel onto the channel with the higher gain setting. Try to track this down a bit by experimentation. For example, do you hear this with NO connections at all, but with the gain turned up on one channel?
Please try a few things to narrow this down a bit and I'll try to provide you with some options.
Thanks,
Dan
Jul 20, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie D8B Mixer freezes
Don't know your setup but have you checked out any possible Hum loops? Have you updated any firmware updates? Is your mains input clean (no spikes or very short drop outs of voltage)? Are you near any possible RFI, e.g. Taxi's or CBr's? The list goes on so check out the Mackie forum on the web for more. Good Luck...
Regards,
Frank.
Apr 07, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
496 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
