Question about Walgreens Studio 35 Film Camera
Just replaced film and now it wont advance and the button wont press when i try to take a picture and the little sign says open
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
We have a Canon A1 that hasn't been used in years. We loaded it and used it a few times yesterday, but now it wont' advance the film, it's stuck. Ideas?
Could it be that it thinks it needs to have the trigger pressed?
The film will not advance past an unexposed frame.
The other possible is that the end of the film has been reached.
Try pressing the release button and rewinding the film.
If you have a dark room available you can always resort to opening the camera.
Excellent camera. Have had one for many years back when film existed.
Mar 02, 2016 | Canon A-1 Manual Focus 35mm Film Slr...
Just loaded film and cant take picture, its not advancing
You need to add a little more information about what you did exactly.
Did you pull enough leader film out? If I had to guess, I would say the film wasn't rolled far enough onto the "advancement reel" so you are not able to advance it because the camera doesn't think it has film in yet.
Nov 14, 2011 | Vivitar V3800N 35mm SLR Camera
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me...
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
Oct 18, 2010 | Nikon FE 35mm SLR Camera
How do i know when my battery is dead. Every time my pictures are developed, they come out black. how do i use the exposure meter?
The K1000 is all mechanical, the battery only powers the light meter. So even if the battery is dead, then you should still be getting images even if very over or under-exposed.
If the images are totally black on the negatives, then your shutter is stuck open and massively over-exposing your images. If the images are black on the prints, then the negatives have been unexposed and will be totally clear. The latter problem means that the film has not been exposed at all and is either due to incorrect film loading, faulty film winding, or a shutter which fails to open.
To eliminate the possibility of a shutter fault, hold the camera up to the light with the camera back open and fire the shutter at each setting. You should see light as the shutter opens and from 1s to 1/30s should be able to see and hear the difference at each speed.
To check film loading and advancing correctly, load a film and wind film on (remember this camera needs the film leader to be manually engaged onto the take-up spool). Use the rewind crank (do not press the rewind button) to take up the loose film and take a few shots. You should see the rewind crank turn each time you advance the film if it is correctly loaded and advancing. If not, open the camera back and visually inspect the film. It should be securely engaged into the take up spool. With the back still open, advance the film and take a few shots: the take-up spool should be advancing and the sprocket wheel (just before the spool, it's the wheel which engages the holes at the edge of the film) should also be turning. If it isn't, then the film rewind mechanism is faulty and the camera is behaving as if the rewind button has been pressed. It's usually easy to remove the bottom of the camera to check that the button isn't sticking.
If all checks so far are OK then check the film pressure plate on the inside of the film door. It should be able to give a little when pressure is applied and holds the film firmly in contact with the advance sprocket, if not then one of the seating pins on the flat metal spring may have become dislodged and it's usually easy to reseat it. Clean the plate after touching it as it must be grease-free and spotless.
If you try all this and still have a problem then please add a follow up comment and I'll try to respond asap, but bear in mind that as I'm in the UK I may be in a different time zone to you.
If I've fixed your problem, then please take a moment to rate my answer.
Aug 19, 2010 | Pentax K1000 35mm SLR Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Film advance lever is loose, shutter button wont click. I was taking pictures, and the lever seemed a little harder to push, but not that much of a difference, then all of a sudden, it got loose, and the...
That is one old film camera. There is a screw under the glued on button on the film advance. If you can't advance, you can't fire the shutter. If that is all the problem, then it should work for awhile.
Jul 06, 2017 | Vivitar V3800N Zoom 35mm SLR Camera
I release the small black button on the back of the camera and tried to rewind it but iy won't do it. I am afraid to loose my pictures. Please help me.
On the bottom you have the Film rewind button. On the top you have the film rewind knob with crank . Here are the instructions on how to rewind the film. You can tell you have reached the end of the film by the frame counter and the film advance lever. Either the film advance lever will not turn at all or it will not turn all the way. First press in the rewind button, you may immediately let go of it, its on the bottom as shown before. Then turn the rewind crank clock wise until the frame counter, which counts backwards as you rewind, reaches "S" then open the back cover, remove the film, place it back in its canister and have it developed as soon as possible.
Oct 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Walgreens Studio 35 Film Camera Logo
29 people viewed this question
Top Walgreens Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Walgreens Photography Expert? Answer questions, earn points and help others
