Question about Radio Communications
I have a set of Motorola Talkabout AZ489FT4818. One of which can not be recharged, even after 3 days. Any suggestions as to what else to try or check? Also, where else can I buy a AAA cassette for the pair? Thank you
  • 391 Answers
Hello you can find the batteries on ebay just look up the model and it will bring them up for you goodluck, your problem is the batteries
Posted on Mar 26, 2011
Charging adaptor for motorola talkabout T5022 bought in USA
You might try contacting wirelesspro.com. They are very knowledgeable on the TalkAbout line of radios.
Best regards.
Apr 07, 2013 | Motorola Battery For Talkabout T5022 T5025...
Why does my motorola talkabout radio shut off when I try to radio someone
Low, defective, or poorly charged battery. It takes more energy to transmit than to receive. On a low battery you can sometimes listen (receive) all day, but one press of the PTT and your radio will shut down.
Solutions:
1) Try radio with a known good battery, or swap the battery from the other radio for a true test and see if the problem leaves.
2) Recharge or replace rechargeable batteries every 18-24 months.
3) Clean all battery contacts with a pencil eraser to assure good connection before charging.
If none of these solve your problem, the radio itself has an issue and needs replaced.
Best regards.
Jun 12, 2012 | Motorola Radio Communications
My talkabout t5000 got water in it how do i fix it and make it turn on
As a last ditch effort:
1) remove the batteries or rechargeable battery pack. Do not reinstall or try to transmit until the unit is thoroughly dry.
2) Dry the unit inside and out with a towel.
3) Dry the unit more with a blowdryer on low heat.
4) Some have suggested placing the unit in dry rice or silica gel packets for a day or two.
5) Once your are certain the unit is completely dry, you can try batteries in it. If your rechargeable battery pack was saturated too, you will need to replace it.
This radio will still have the likelihood of growing corrosion, which will eventually cause the radio to fail. However, if you can get it dry, you may be able to get some more time out of it, before you need to replace it.
Sep 05, 2011 | Motorola Radio Communications
Greetings, I have 4 Motorola Talkabout T5720s bought all the same time about 1.5 years ago. 1 failed after a year - I say failed (did not transmit or receive nothing even though it was on the same...
You did not mention if the display comes on and they look functional, yet do not work. If the radio actually powers up. We will go from the idea the radio powers up and present a few troubleshooting ideas:
1) Clean your battery contacts. Use a pencil eraser and clean the contacts both in the radio and on the battery. If you are using a Motorola rechargeable battery pack, you should also clean the battery contacts on the charger. (Note: rechargeable NiMH and Li-Ion batteries have a 14-18 month life expectancy. Signs of a bad battery include: no or intermittent transmit, the radio shutting off when the PTT is depressed, lots of static when receiving, and/or erratic display.)
2) Set your interference code eliminator (code) back to zero (off), and do the same with your Qt filter if you radio is equipped with one. This will put you back to a very basic operation.
3) Check your VOX or iVOX settings, be certain these are also turned off.
4) Check your accessory jack to see if something is plugged into the hole. Remove any and all accessories to try in a basic form of operation.
5) Moisture is the enemy. Be certain radios are not stored near air conditioners, humidifiers, etc.
If the above items do not solve the problem, you likely will need to retire the units. As for your next venture. If you go with the Motorola TalkAbout line, examine your radios before the one year mark, save the receipt, most have a one year warranty. If you are wanting an all around better radio, look at the Commerical line of radios offered by Motorola, ie. CP110 and BPR40. They would offer a better durability and are designed to do a 40 hour work week.
Best regards.
Feb 02, 2011 | Motorola Talkabout T5720 (7 Channels)...
My phone thinks it has low battereys
Rechargeable batteries eventually won't work after being charged and discharged many times. You can purchase a replacement battery for your phone at a local electronics store or online. (alot of ebay sellers will have replacements).
Jun 08, 2009 | Motorola Talkabout T8097 Cellular Phone
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
Older Motorola Talkabout FCC ID AZ489FT4818
You can find a copy of the user manual at http://www.motorola.com/mdirect/manuals/T280_User_Manual.pdf
Which has the instructions on how to program the Talkabout TA280 and TA289. From your FCC ID number it appears you have the Talkabout 280SLK.
Oct 19, 2008 | Radio Communications
Motorola talkabout t 6530
I just spoke with Motorola and they advised output for that particular charging base is 9 Volts 200 Ma output hope this helps, good luck!:)
Nov 11, 2007 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
119 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
