Question about HP Pavilion s7320n (EP140AA) PC Desktop
My problem is simple to describe: The computer starts and runs fine,except for the smell...and the heat. The smell resembles burning plastic,and the heat output is noticeably higher. There's no smoke visible. My question is this: Is this a fan issue,or something worse?Elwood
  • 83 Answers
Laptops do tend to get hot from normal use but you shouldn't be experiencing a burning smell. Do you feel any air blowing from the vents? Download and install Fan Speed.This will give you some good information about your hardware temperature and fans. If you do have a failed fan and high temperatures, don't use the laptop until you get it repaired. You could fry your motherboard and/or processor.
Posted on Mar 26, 2011
    Sergeant:
    Novelist:
  • 185 Answers
It more than likey seems to be your fan if the heat from your tower is noticeably higher and the smell.
If computer still under gaurantee you will be able to get it repaired for free from the manufacturers.
If not, take the tower cover off, and get a hoover and **** all dust particles from the system.
You may also need to invest into another fan, this should stop the smell and also the overheating
Hope this helps and please rate thanks.
My Frigidaire oven model feb386wech emits a burning plastic smell when heating up and cooking. What's causing this?
After 16 years of service, the oven may be starting to consume itself. I have found melted light fixtures and scorched, brittle wiring. If you can't isolate the source of the smell, it could be time to replace.
Nov 13, 2016 | Frigidaire Microwave Ovens
Burning smell from drivers side rear wheel
This happens often on Fieros. It turns out that the clamp that holds the brake hose rusts. The rust presses against the hose, restricting it's flow. You don't notice when the brakes are worn and basically not working, but after repairs you get locked up or overheated brakes. Remove or replace clamp and or hose.
Oct 05, 2017 | 1995 Honda Accord
A plastic lid melted on the coil, still smells like "melted wax", seems clean, what can I do?
You will probably have to replace the heating coil in the bottom of the dishwasher to get rid of the smell. The coils aren't that expensive and replacing them is an easy job. Hardest part is getting the dishwasher out from under the counter to do it.
Feb 19, 2014 | Whirlpool Dishwashers
My 2012 Harley Davidson Ultra over heated while idling with a burnt smell
Hi anonymous, asked and answered. Thank you
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 15, 2014 | Harley Davidson Motorcycles
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
When the machine is switched on there is a smell of burning / hot plastic. i have removed the front cover and there is no sign of any heat damage to the controls or PCB. The wachine works fine, except for...
Have got the same problem at the moment. Removed all the covers and checked the control panel ( no damage, no smell ) The drain motor ( no damage, no smell ) and the drum motor again no obvious problems. Checked the brushes on motor and they were fine also. Have decided to let whatever it is run itself to destruction and then hopefully i can identify it.
Will post on here if i can resolve.
Feb 25, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Burning smell when heat is on
Have you looked at the exhaust pipes for oil dripping and burning off??
Feb 10, 2010 | 2006 Acura TSX
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
HP Pavilion s7320n (EP140AA) PC Desktop Logo
413 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
