Question about Maisto 2004 Ford F350 Super Duty HarleyDavidson Edition for DS
6.0 diesel starts rough low on power until warmed up
    Problem Solver:
  • 8 Answers
Unfortunately this is a very frequent problem for this motor. Not a lot of answers as its a compression issue. If the engine is blowing a lot of white smoke after it starts and while its idling rough, you may have an injector(s) that are dripping or not spraying correctly. Only a diesel/injection shop or dealer will be able to test your injectors to ensure they are opening at correct pressures.
Hope this helps.
Posted on May 22, 2011
I have a 1997 SAAB 2.0 Turbo and it has started to run rough after it warms up and when driving it loses power and runs very rough until power taken off. Any ideas?
suspect low fuel pressure to the injectors
run the fault codes to determine where the fault may be before you spend money
Oct 09, 2015 | 1997 Saab 900
2002 mustang gt cold starting the runs rough and stays that way until it is warm.
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 18, 2014 | 2002 Ford Mustang
MY 2006 6 LITER DESIEL IDELS AND RUNS ROUGH WHEN I FIRST START IT UNTIL IT WARMS UP THEN IT JUST HAS A SLIGHT MISS. I PREVIOULY HAD LOW TURBO BOOST AND A DIRTY EGR VALVE I CORRECTED THE PRBLEMS AND CLEARED...
Your pre heating circuit may not be working properly. It should cycle for a bit when you first start the engine. Also it may be a good idea to change the fuel filter. Haynes has a Diesel Engine Repair Manual, part # 10330 that may prove to be a help for you. Hope this helps.
Mar 14, 2010 | 2006 Ford F-250 Super Duty
F250 Diesel engine won't start in cold weather
check your glow plug relay! located on the right side head
Dec 27, 2009 | 2003 Ford F250 Super Duty Crew Cab
Hard starting diesel, at approxamately anytime temp gets below 45 degrees F. runs rough when started, smokes, then once warmed up no problem. Has quit on me twice in traffic.
only 2 things can maake a diesel run rough at start up ,,1--- air in the system 2----- 1 or more of the glow plugs not working. this sounds like the latter ,if you have a couple of glow plugs not working ,it will miss on those cylinders until it warms up ,and the smoke is mostll exesive fuel when it does fire . recommend you check the glow plugs
Oct 11, 2009 | 2001 Ford F350 Super Duty SuperCab
1992 gmc sierra turbo diesel starts and idles fine until warm up
It's time for a Italian tune up!
The blue smoke can be one of two thing.
oil drop from the valve stem (from engine head to cyclinders)
or
diesel soot collect inside the exhaust system.
I will take a 5-10 minutes high rpm (not redline) ran on the highway.
Pay close attention to the rear view mirror and look for black diesel soot.
=== I will use Diesel Cleen or similar product to condition the fuel. (keep moisture down)
Use the recommended amount of SEAFOAM oil additive to condition the valve stem seal/rubber parts.
I can not rule out excessive blown by.
Can you get a diesel compression tester?
When was the last valve adjustment?
Please post the actual odometer on the engine and I will follow up on it.
Apr 21, 2009 | 1992 GMC Sierra K1500
Toyota diesel is rough on initial cold start up
Could be injector problems. is the car down on power?
Feb 27, 2009 | 2005 Toyota Avalon
Ford f250 2005 with 6.0 diesel
I have a 2005 Ford F250 4x4 supercrew, When I first start the engine the truck has no power and will not run good until it warms up which takes about 5 mins. How do i fix this
Nov 18, 2008 | 2005 Ford F 350 Super Duty
2000 F-250 7.3 diesel, cuts out runs rough no power
Well, you have to let diesels warm up before you drive them so the engine gets warm and it may not sound right at first because if its not warm the compression gets off and doesnt fire right. If you try to give it too much gas before its warm, extra diesel will get in the cylinders and misfire. Then when it does fire, there is a lot of extra fuel in it so that causes the smoke and smell. You should always let it warm up for a bit before driving when you havent driven it for a while.
Oct 20, 2008 | 2002 Ford F250 Super Duty SuperCab
Maisto 2004 Ford F350 Super Duty HarleyDavidson Edition for DS Logo
64 people viewed this question
Top Maisto Video Game Consoles & Games Experts
James Wishart
Are you a Maisto Video Game Console and Game Expert? Answer questions, earn points and help others
