Question about Sharp AR-C260M All-In-One Printer
Sharp AR-C260M The Error Code is L4-07 - Sharp AR-C260M All-In-One Printer
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Posted on Jan 28, 2009
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
Error code h4-01 ar-c260m?
Your fuser is not warming up in time. 01 is for HL2 the lower heat lamp. Cancel with Sim code 14/execute/yes and let the machine reboot. If the code comes back you must replace the lamp.
Jan 29, 2011 | Sharp AR-C260M All-In-One Printer
My Sharp printer AR-C260M has an error sign "F2-43." It appears when I first turn on the machine and I can't use it at all.
Your machine is starved for yellow toner. Your yellow cartridge may have run out or its' countdown chip went to zero without the copier alerting you, sometimes this will happen on these models. Try replacing your yellow toner cartridge.
Nov 16, 2010 | Sharp AR-C260M All-In-One Printer
I have a Sharp AR-C260M Machine. Does anyone have a way to bypass the routine maintenance code that comes up and basically locks the machine up until you call for service.
Go to Sim 26-38 and set to zero. when your machine reboots and still locks up you will have to reset some of your counters (drum, transfer, etc)
Apr 07, 2010 | Sharp AR-C260M All-In-One Printer
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Nov 19, 2009 | Sharp AR-C260M All-In-One Printer
Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
Sharp AR-C260M All-In-One Printer Logo
178 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
